Results 271 to 285 of 923
12-07-2011, 06:40 AM #271Registered User
- Jan 2007
- lindenhurst
- 1,831
- 11
- 43
If i remember correctly you have cable steering??? Throw that in the garbage.... Hydralic steering is much better with no torquesteer at all.. Also there is a thread bragging about a 250 etec on a 21 super runnin 86 with a 30 pro et ( 1 person, im assuming lighter on fuel because it was for testing purposes).... My 225 based motor which makes around 30 less hp the an HO etech pushes my boat to 84 every day
12-07-2011, 08:40 AM #272
Hey Mike
Were keeping our eyes open for a used Latham set up. Sure will miss that tilt wheel helm.
12-07-2011, 09:03 AM #273
12-07-2011, 09:18 AM #274
I think the 80's Stepp and Regal hulls had a 6inch step while the newer hulls >1996 were designed with a 9inch step.
12-07-2011, 11:06 AM #275
12-07-2011, 12:29 PM #276Registered User
- Jan 2007
- lindenhurst
- 1,831
- 11
- 43
12-07-2011, 01:12 PM #2775000 RPM
- May 2008
- Glen Spey, NY
- 402
Yes I do have cable steering. As far as not being impressed have you driven a boat with the e-tec? If not at the romp I'll let you drive mine. I think you have been a bit critical on them. Maybe I can change your mind maybe not, but if getting great reliability and exceptional fuel economy for a mph or two makes it not cool so be it .... sign me up. You bleed black I bleed blue and thats o.k. As far as your old boat with the Merc I would love to see him at 100. We all want to go faster or we would have a Bayliner and not care. Ben do you have low water pickups? Just curious. If not in the spring I'll have to go up to the last hole and try it. Keep dialing guys.
12-07-2011, 04:25 PM #278Registered User
- Jan 2007
- lindenhurst
- 1,831
- 11
- 43
I have no problem with the Etec.... Just a local guy speaking of how great it is because the boat went a certain spead... The speed is the part that doesnt impress me thats all... Its not relative to you and your boat at all
12-07-2011, 11:47 PM #279
12-08-2011, 02:40 PM #2805000 RPM
- May 2008
- Glen Spey, NY
- 402
The main issue on running a motor too high is the water pressure? What pressure would be acceptable? Second too last hole its running 15-18 lbs on the gauge. No budget for hydraulic steering or a jackplate at this time. They kind of go hand in hand as I am not sure there is enough play in the cable steering( that was just replaced three years ago )to hang a jack plate . I do believe there is more left in my boat with jackplates and a larger prop but it pulls double duty as the family tubing and camping boat so completely dialing it in is not realistic. As far as the e-tec not running good numbers on the other thread I think 86 is pretty respectable . Dialing in anything other than a Merc is a bit challenging as Most guys are running them and the wealth of knowledge seems to be endless as is the power adders available. Merc definately has the upper hand on hopping up stock motors. That is the one negative I do find with the e-tec. Still waiting to hear the numbers guys.
12-08-2011, 03:03 PM #281Registered User
- Jan 2007
- lindenhurst
- 1,831
- 11
- 43
I must just be spoiled because my 225 based motor that still makes less then a stock 250 drove both of my boats to 84 ...
12-08-2011, 04:00 PM #2825000 RPM
- May 2008
- Glen Spey, NY
- 402
Yup your motor does run.
12-08-2011, 05:30 PM #283
As long as you have 12 or 13 lbs you should be fine. You can always close off the top 1/2 of you water pick up to go higher, that should be fine on the transom at top hole. As far as Ben having a water problem on Saturday, had nothing to do with height. The last time I used that gear case I had to tow someone in who was cloged with sea weed and I got cloged too and wasted the pump and paddled in myself. I checked the pump and it looked fine but I guess it wasn't cause a new kit fixed his water problem Saturday. He went out for a last run today and got 86 with a 27 labed Hydromotive OB4 at 6200. He said it had more but it was windy and he wants to get more use to the boat. Were takeing it up to Long Lake to store it for the winter so thats the last of the #s unless we take it for a ride up there. Big thanks to ChrisM weere gonna store it next to his twin engine Shadow. I'll post a picture of the 2 boats together Sunday night when I get back. Have a good weekend you guys.
12-08-2011, 05:49 PM #284
12-08-2011, 07:42 PM #285Registered User
- Jan 2007
- lindenhurst
- 1,831
- 11
- 43
Bens boatt will really fly once he finds the sweet spot in the setup. I run 8psi water pressure on the fast passes, thats right on the edge of blowout, and also the limit for low water pressure
