Results 136 to 150 of 923
07-13-2011, 03:08 PM #1365000 RPM
- May 2008
- Glen Spey, NY
- 402
Whats it going to be a 14 ft aluminum with the Merc and a fishin pole?
07-13-2011, 03:11 PM #1375000 RPM
- May 2008
- Glen Spey, NY
- 402
Jim, I am not going although I wouldlike too. My wife is going into labor as I write this so hopefully this is the real thing now. Have fun.
07-13-2011, 09:24 PM #138
08-06-2011, 07:56 PM #1395000 RPM
- May 2008
- Glen Spey, NY
- 402
Well i was finally able to mess with the prop vent hole plugs and try it without too many other people on the lake. Again not gps confirmed but was able to see consistent 82 mph out of it were it was reading a high of 80 before ... So raising the motor hight and using the 27 trophy seems to have freed up some speed. The boat seems to run a little flatter and does have quite a bit of torque steer now were as before it almost had none. I will try raising it to the last hole maybe this coming week. Hopefully see more speed and not get worse on the torque steer issue...... Still better than the 3.6gt as far as torque steer goes. Mike any pictures yet? Havent had too much time to browse all posts.
08-24-2011, 04:49 AM #140
Hi Guys great thread
looking for info on set up on newer 22 2011 ,regular lay up,
225sportxs vs 250xs vs 250proxs (love the sportmaster which gear ratio)
transom or jackplate (if so just want fixed)
Can i hit 80 with the newer boat(heavier)
08-24-2011, 07:23 AM #141
Post us a few pictures of the new rig.
08-24-2011, 08:08 AM #142
Sorry i was not clear no pictures yet gonna be a new rig
Parts are being purchased/decisions are being made
Need advice
Be glad to document build as she comes together
08-24-2011, 09:06 AM #143
SM or TM
I have the past summer with a very carefullness tried out the TM vs SM houses.
I used the same boat, engine and prop for both setups. V22/300XS/Merc Racing Bravo XS 27"
They are very close to each other on WOT but in the mid range the TM rules a lot with both better speed and consumption.
Ex Figures
WOT 6300 rpm SM 82,1 Mph along pad
WOT 6300 rpm TM 81 Mpm along pad
Mid 4500 rpm SM 51 Mph 2" below
Mid 4500 rpm TM 56 Mph 2" below
I should go for the TM if I were you. Here in Sweden lots of Boatowners buys nosecones and SM-lower units without trying them out. In my opinion there is hard to find more speed with a SM with a Velocity 22 but it is a lot safer at 80 Mph an up.
I could also easily run the both SM and TM along the pad without any probs.
Here is two pics from the summer.Last edited by Tistronskar; 08-24-2011 at 09:09 AM.
08-24-2011, 03:04 PM #144
Awesome pics Tistronskar
Thanks for the info
Is P a race class in sweden ?
What gear ratio are you running?
What is your layup fiberglass or kevlar ?Last edited by limitless; 08-24-2011 at 03:23 PM.
08-25-2011, 07:20 AM #145
Thx
Thanks for the info
No, I think we have the same classes that you have. I just felt the hull was a little bit naked. But the sticker is all gone now bacause of the water&wind etc. The P stands for my name, Patrik and was born in 1964.
1:75
What is your layup fiberglass or kevlar ?[/QUOTE]
Kevlar, I called Steve Stepp last year and gave him my serialnumbers and he rembered my hull very well. He said it is only 20 pieces built in 100% Kevlar after 1994. Unfortunately the later is not as fast than the early V22s.
Maybe I can find a few more Mph if I extend myDetwiler 7" with a 4" Bobs bracket. If it works fine then I will buy a instant 10-12" Hydralic Jack Plate.
I also did a brand new transom last winter.My god...it was all wet and rotten. I even had to get rid of the fueltank beacause the standing "balsa" (wood, i not shure if I had the right name?) was rotten all the way under the fueltank.
Cheers. PatrikLast edited by Tistronskar; 08-25-2011 at 08:46 AM. Reason: pics
08-25-2011, 08:42 AM #146
08-26-2011, 09:37 PM #147
Hey sorry this response has been so long in coming
Wow what can i say i thought your rig looked new
you've really built quite a piece
Im really excited to begin mine
I'll keep you posted
Thanks again for your insight
09-20-2011, 06:47 PM #148Registered User
- Jan 2007
- lindenhurst
- 1,831
- 11
- 43
Who has some updates????? Somebody with a 250 or smaller has to pass my top speed by now??
09-20-2011, 07:34 PM #149
Nothing news breaking for us lately.I did see 76 with the wife,myself and 50 gallons of gas in it,during a run around Baindbridge Island.I wasn't able to do much at all with it this summer,had a lot of things going on around the house.I do have a few ideas for over the winter that ill be doing.I do think touching 80 may be possible,but it won't do it everyday with a 250xs.These newer boats are definatley solid built to say the least.
09-21-2011, 10:36 AM #150
Tistronskar - what year is your boat? Looks pretty new. It must have a rough life peviously that it needed a new transom?
You cannot bring about prosperity by discouraging thrift. You cannot strengthen the weak by weakening the strong. You cannot help the wage earner by pulling down the wage payer. You cannot further the brotherhood of man by encouraging class hatred. You cannot help the poor by destroying the rich. You cannot keep out of trouble by spending more than you earn.
