Results 151 to 165 of 180
05-12-2010, 05:20 AM #151
09-27-2010, 04:18 AM #152
man i heard a guy that had this (or similar) the other day... and i wish i had the balls to do this... it sounded sweet... i wish talon would drive on over to SO IL and do this for me ... ill buy the beer
05-05-2011, 10:31 PM #153New Member
- May 2011
- georgia
I want to make my 1994 Mercury 175 XRI Black max louder but I don't have all the tools to be pulling the power head etc to remove the exhaust can. Can't I just drill two 1 inch holes in the rear of the mid section above the water line to get some sound? If you want it quieter then plug it with 2 rubber expansion plugs? If you drill through the mid section can't you keep drilling and drill though the exhaust can or will it still need to be removed? I am just a little confused on why you have to remove the can and why can't you just drill through the mid and into the can.
03-20-2012, 09:12 PM #154Junior Member
- Jun 2007
- old town florida
- 17
ttt
so i can find again
03-21-2012, 05:36 AM #155
On the use of expansion plugs.........I'd think you'd probably melt them if you run your motor for any good distance, you gotta remember, there's a lot of heat coming out of the exhaust and you'd need a special rubber that will withstand those temps, not to mention chemical attack from fuel and oil.
You can drill through the mid and into the can, but the net results will not be as you would expect. It's going to be more like a leak in your cars exhaust pipe. In order to get that deeper throaty sound the can needs to be either removed and replaced with a tuner or the can get's cut short. The whole concept here is to be able to use the entire mid section like an amplifier where the sound is able to expand and gets deeper in sound. I've done several mid exhaust mod's and anything less than at least 2, 1 3/4" dia. holes will not give you a decent sounding exhaust. Think twice before you cut...........
11-18-2012, 08:15 AM #156
Posted 10-12-2002, wow 10 years ago, time sure has flown by.
10-20-2013, 10:46 AM #157
And this is still a 100% kickass thread! I just found it and will be doing it to mine soon. Thanks Talon.
01-18-2014, 12:08 AM #158
02-08-2014, 09:12 AM #159
02-08-2014, 10:35 AM #1605000 RPM
- Oct 2010
- Seaford, NY
- 708
- 41
- 18
Love if any updates since this is an old thread, any mid cracks or other problems??
02-08-2014, 10:38 AM #161
No issues at all and still love'n every decibel........
Clip: http://www.youtube.com/watch?v=2IhSRiwvGwA
whipper liked this post
07-08-2014, 09:02 PM #162New Member
- Jul 2014
- Cedarburg wi
Talon I'm new to this.
If your still a member I would like to ask you how to remove the can on my 96 Mercury 175 efi.
i have a checkmate 185 pulse.
i would like the loud sound from my outboard.
thanks
07-09-2014, 03:23 AM #163
It's not as simple as removing the can. You must still keep the exhaust can but you may be able to remove/cut off the bottom section. I'm not that familiar with the exhaust inners of a 175, hopefully someone who is familiar will jump in here and express their way of doing it. Post up your motor S/N and I'll look at the mid section views.
10-31-2014, 01:13 PM #164
Did this modification to my 2.5 200 last week...WoW love the difference in sound AND picked up a little better holeshot.
SlimmHire the handicapped, we're fun to watch
Talon2.5 liked this post
11-02-2014, 03:14 PM #165
