Results 1 to 13 of 13
    Feb 2010
    okc
    Bulkheads what are they
    I posted a hread earlier and wanted help with stiffenind a deck some one said to install bulkheads im new to these terms and want to know what they are and where to get them and how to install them
    Oct 2003
    Quebec Canada
    A bulkhead is basically a wall installed every so often to strengthen a large open structure. They don't need to be solid like a true wall.
    Blizz
    Nov 2005
    NE Alabama - Weiss Lake
    Think of a house framed in. The interior walls are the bulkheads which serve exactly the same purpose - strenthen the total structure.
    Another analogy which is more accurate would be the ribs in an aircraft wing. The ribs in nautical terms are bulkheads and provide points to rivet the aluminum skin (fiberglass deck) to make a strong structure.
    A submarine is also composed of a long steel tube with vertical bulkheads every so often to strenghen the structure. They put doors in those vertical bulkheads to allow passage between compartments and that is why Blizz said that they dont have to be solid. That is also why the wing ribs in an aircraft wing have holes in them - to make them lighter.
    longisland
    Billy don't be so mean!!
    Nov 2005
    Yes obviously he needs help but I tried to give him the definition and the purpose of a bulkhead. Sometimes if you know the "why" and "what it does" that is a big help. Maybe the guy is a house framer and knows nothing about boats. If we could put it in his terms - which I tried to do - he would at least understand WHAT needs to be done and why. If he has the skills to do it is another matter which will probably be addressed here again.
    Nov 2005
    This is for Eddie. No one makes bulkheads that you can just install. You have to make them and then install them. If you want to do that I or any other fiberglass savvy person on this forum can tell you how to do it.
    Feb 2010
    okc
    thanks i would like to know more i am new but as with everything that has ever been done by any and every one there had to be a first time for us all right ??????????????
    Feb 2010
    okc
    Or maybe is there someone in the okc area who wants to do the job or look at it and see if i even need it
    Maurepas, Louisiana
    Quote Originally Posted by eddie baird View Post
    U rite,,,, not ALL of us woke up as savvy as others think they are.
    Russ
    Russ Benton
    Allison XB-2003 w/JSRE Pro Max
    Allison XR-2001 w/260 +
    Feb 2010
    okc
    How did that guy billy get his post to disapear
    You can delete any post you make, or thread you start, just hit the edit button on your post, you'll see a "delete" option.
    Feb 2010
    okc
    still looking in okla for some who know about installing a bulkhead for me
  13. #13
    Sep 2002
    Anytime you stiffen something that vibrates, something nearby is going to vibrate instead, usually starting some new stress cracks. They try to design broad areas like decks to have even, uniform flex...
