Results 1 to 15 of 25
Thread: New Superboat 16' CC build pics.
04-09-2010, 06:12 AM #1
Started a 16 and 24, both CC's. Here are the 16 shots. enjoy
Making the compartments for the foam floatation
Deck is compete.Rick
Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut. ~Ernest Hemingway
04-09-2010, 06:22 AM #2
here are some of the hull build pictures.
The white gelcoated area in the bow is a huge storage compartment, which the original 16's didn't have.
Balsa core extends all the way to the bow. Between the two bulkheads will be filled with foam, also the outside of the stringers are also filled with foam.Rick
04-09-2010, 06:26 AM #3
Next the floor goes in. It is assembled and glassed together outside the boat as 1 piece.
Rick
04-09-2010, 06:29 AM #4
Yesterday I cut the rigging holes and installed the rod holder boards and popped the hull. Also gelcoated it.
Rick
04-09-2010, 06:31 AM #5
Deck is popped. Will pull it today and install hardware and get it on the hull.
Rick
04-09-2010, 06:58 AM #6
Nice Clean work
Looks good. thanks for the picturesFormula 260ss 496HO
Bender Clan Member
04-09-2010, 07:07 AM #7Screaming And Flying!
- 14,700
- 380
- 1279
- 5599
- 10929
Good to see the shop is still able to keep busy in this crappy economy. Nice boat, simple yet very solid construction. Keep the pics coming. I am sure everyone enjoys seeing the boat construction process.
04-09-2010, 08:35 AM #85000 RPM
- Sep 2004
- Ft. Lauderdale
- 691
- 9
Great pics, felt like i was there!
04-09-2010, 10:42 AM #9
Looks good, is that marine grade plywood? just asking due to the # of knots?
04-09-2010, 04:05 PM #10Rick
04-09-2010, 04:22 PM #11
Looks very nice
How do you apply that gelcoat? With a brush or roller?
How much grams/m² and how much pigment?
I realy like the gelcoat floors but I dont like the weight. I used 23pounds to do the the entire inner side of the hull up to the rubrail for a 18Ft boat. Which is a lot of weight in my opinion. If I would paint it than it can be done with maybe 3pounds of paint...
04-09-2010, 04:42 PM #12
The interior of the hull took 6 Qts., or around 14 Lbs. Roll and tip the sides and roller on the sole. I don't add pigment, I use Gelcoat.
Rick
04-09-2010, 05:19 PM #13
04-09-2010, 06:33 PM #146000 RPM
- Aug 2007
- Commack, Long Island NY
- 1,338
Thanks for posting Rick.
Very cool and nice work ....
04-09-2010, 08:03 PM #15
1982 12' Eli with 7.5 Evinrude (sold)
1963 16' Glasspar with 40 hp Evinrude (sold)
1969 13' Boston Whaler with 40 hp Evinrude (sold)
1990 20' Searay with Merc i/o (sold)
1990 22' Activator with 2.5 EFI (sold)
1998 24' Superboat Step Hull with 300 Pro Max (sold)
1983 21’ Shadow with 300 promax
2003 13’ Boston Whaler with 40 hp Merc
1976 16' Superboat with 75 Yamaha
2010 30' Superboat Center Console with twin 300 Mercs
One good hour on the water will make you forget 24 bad hours on land
