Results 1 to 13 of 13
Thread: venting a holly red
04-04-2010, 12:12 PM #1
venting a holly red
I just picked up a Holly red pump.How are you guys venting this pump.
Its a 712-801-1
Its the 1705 Marine pump.
Thanks for any help
04-04-2010, 04:07 PM #2
Ventint
What are you refering to? I have used the Red pumps for years and have never heard anything about venting them.
Carter Powell
04-04-2010, 04:31 PM #3Banned
- Aug 2009
- new iberia la.
- 336
Good question Carter Powell. I was wondering the same. Thanks Martin
04-04-2010, 04:48 PM #4
Here are afew pics
My hot rod Motor builder friend order this from holly last week for me.Now ive also ran the red holly in my other yt and its nothing like this one...Mabie its all new from holly
But please see the added pics.Last edited by hydrostreamvking4m; 04-04-2010 at 04:53 PM.
04-04-2010, 05:20 PM #5
The marine pump has the extra nipple on it so that if there is any internal damage done and it breaks the sealing ring inside it will be pushed through that nipple as opposed to just dumping it in the bilge. On my fathers OMC I ran a fuel line from that nipple to a fitting on the intake, so that if it were to break internally it would just flood the engine as opposed to running the engine lean. But you can just loop it back to the fuel tank as well.
It is one of those items that probably 9999 out of 10000 it will never be needed but if you do need it, it is better than having fuel dumping in your boat.
04-04-2010, 05:39 PM #6
[QUOTE=outboards4life;1942454]The marine pump has the extra nipple on it so that if there is any internal damage done and it breaks the sealing ring inside it will be pushed through that nipple as opposed to just dumping it in the bilge. On my fathers OMC I ran a fuel line from that nipple to a fitting on the intake, so that if it were to break internally it would just flood the engine as opposed to running the engine lean. But you can just loop it back to the fuel tank as well.
All good info right there!!
All marine Holley's have those vent fittings.
I vented back into my slosh tank because I run a slosh tank.
You can vent back into your gas tank by putting a small hole in your filler hose and inserting a 1/4 bard coupling so you can attach the hose.
04-04-2010, 08:54 PM #7Banned
- Aug 2009
- new iberia la.
- 336
Wow man, never knew it existed. Makes sense!!! Thanks Martin
04-04-2010, 09:15 PM #8
Yep, Holley makes the red and the black in Coast Guard approved Marine versions that are vented. Coast Guard wants if vented back to the intake or to the tank.
Steve Schefer
04-05-2010, 08:49 AM #9Scream And Fly VIP
- Mar 2004
- Tulsa, Oklahoma
- 451
I have an old mech. pump for a BBC laying around somewhere that I had on a jet boat. It also has a vent on it for the same reason, coast guard..
04-05-2010, 09:46 AM #10
2 ounces of fuel in the bilge, and a spark, has about the same effect as a torpedo.
Most fire extinguishers die of old age, unused. However, if you need one, there's no substitute.To fish or not to fish? What a STUPID question.
04-05-2010, 10:13 AM #11
Many BBC's had a return line to the pump which would allow excess fuel pressure back that way instead of blowing the needles off the seats. Chevy bounced back and forth on what they used them on. On some early Special High Perf engines, like the early 60's 409's rated at 425 horsepower, there was a return line, but later, like on the late 60's 427's and 396's, the high horse versions DID NOT use the return, while the lower horse versions of the same engines did. In any case I believe the ones on the BB Chevy pumps are return lines rather than vents or emergency bypasses like the Holley Red.
04-05-2010, 10:22 AM #12
Here are 2 pics I found of my setup for the carb motors.
04-05-2010, 11:23 AM #13
Nice!
Thanks guys.This just the info i was looking for..It sure had me wandering how to run it since ive never seen a holly red with a vent.
