Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 46
    Sep 2007
    Columbia,AL
    LOL. Are you and beef coming up to Ft. Rucker this year?
    Justin Richardson
  2. #17
    Jan 2007
    Amityville/Lindenhurst
    last I checked the home depot over here for muratic acid they stopped selling it because they said someone had gotten burned from it.
    Just buy the on/off from a marine supply store
  3. #18
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by RobF View Post
    You gotta be kid'n me.............I guess they'll stop selling tools to if someone hits their finger with a hammer.................
    Gary
    Growing old is inevitable, growing up is optional.......
  4. #19
    Jan 2007
    The way the guy explained it to me was it fell off the shelf and burned someone, not they had taken it home and done it
  5. #20
    Jul 2007
    Hamilton Ohio
    I understand that, but do you hear what they're saying..........
    A 3 pound sledge hammer fell off it's display shelf and hit a customer on the foot.............................We therefore will not carry anymore sledge hammers.....................
    Gary
  6. #21
    Jan 2007
    I understand your point, keep it out in the garden section on a low shelf, but im sure its also not worth the liability either.
  7. #22
    Jul 2008
    Shreveport, LA
    Muratic acid is available at swimming pool suppply stores. I'ts nasty stuff. PH
  8. #23
    Jul 2008
    Shreveport, LA
    Attwood hull cleaner, available at walmart worked great at getting rid the rid of the riverwater stains on my hull but it's kinda pricey. PH
  9. #24
    Muratic acid is hydrochloric acid.
    I have used a mixture of Lysol toilet bowl cleaner, and hydrogen peroxide. (the medical stuff you use on a cut) Look for the Lysol that lists hydrochloric acid as one of it's ingredients.
    It also helps if you can wash the bottom of the boat before it can dry, right after pulling it out of the water, at the ramp.
    In my experience, waxing the bottom of the boat does make it easier to wipe the algae growth off the bottom of the boat, for a while.
    I have heard that waxing the bottom of the boat can cause gelcoat blisters to form, but I do not know if that is true, or not.
    Is was already said, but keep it off metal parts of the boat, and the trailer.
  10. #25
    Jul 2008
    Shreveport, LA
    The same guy that told me about Attwood also said he'd used TidyBowl before! lol PH
  11. #26
    Jun 2001
    Twin Lake, Michigan
    I use foaming wheel cleaner. It has a little acid in it, but it won't hurt anything else. The "Works" bathroom cleaner works too. I just cleaned the bottom of my Mastercraft, it took 5 minutes and one bottle of wheel cleaner. Using muratic acid will etch the top layer off of your cement and rust everything it touches. It has it's place, but cleaning the bottom of your boat in your drive isn't one of them.
    Bruster's Mercury solid motor mounts, details here:
    http://www.powercatboat.com/Bruster/Bruster.html
    I'm been living in fast forward, now I need to rewind real slow....
  12. #27
    Miami,Fl
    As long as the water is not arround a chicken plant on/off worked for us. Chicken blood stains for good. On/off can do wonders on a galvanized trailor. Rick
  13. #28
    I have been using some stuff called rustaid. Get it at home depot, etc. Spray it on with a little water on the surface. The stuff isn't easy on the finish but will remove any stain. Main ingredient is oxalic acid. Keep the trailer and boat wet while using any strong stuff to keep it diluted a little.
    May 2010
    Pa
    You can go to a truck stop and get a gallon of aluminum cleaner for about 12$ and spray it on and let it set for 5 minutes and spray it off and it will look great I think its called Alluma Brite
  15. #30
    Nov 2005
    Egg Harbor Twp. NJ
    I've found the best way to apply Muratic acid/ On-Off is by using a boat wash brush on a 3' pole. Just use a few ounces in a plastic bucket and dip the brush in and apply to the bottom of the boat. Application is much easier and keeps you a little further from the stuff so you don't choke on it or drip on your hands.
    David
    ______________________
    2000 Powerplay Sportdeck
