Page 21 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 301 to 315 of 357
Thread: new race models
  1. #301
    Dec 2011
    cold lake alberta
    The adapter plate on my gen 2 appear the same, all the fittings are plugged. compressor is fed water from a large fitting on top of the block, no filter or screen, T-stat dumps are routed down and through the bottom pan. Nothing unfreindly about the 15" mid or trim range,it has 3 degrees less negative trim than a 20",.but has no tilt which for anyone with a hyd jack is a non issue anyway. With the wedges I installed yesteday I flattened the holeshot,can keep the boat planing @ 20mph and did not lose top speed with 5 degrees less positive trim. 620 hours,no hiccups.
  2. #302
    Jan 2010
    Vero Beach, FL
    Quote Originally Posted by josh7_78 View Post
    Merc is now accepting 2014 orders on these things for their fall production. Looks like orders/deposits have to be in by the end of September.
    How much deposit they require? Can you order only power heads? I have a pair of Gen 1. Thinking upgrade.
    2001 Velocity 220 - 300
    xs by
    DBR - Sold
    2001 Motion 25, 03-250
    xs's
  3. #303
    Feb 2007
    lily lake WI
    Quote Originally Posted by NAVISPEED1 View Post
    Josh would know for sure but I think merc needs a 30% down as fo just a powerhead they tried that once and they it is very unlikely they will do it again
  4. #304
    May 2007
    STL
    I called. They would do it but the ecu and power head was rediciulous. I think list was 9800 on the power head and 2100 on the ecu plus I would have needed a tuner and adapter plate. .....and you don't get the new sporty or mid
    [IMG][/IMG]
  5. #305
    Dec 2011
    cold lake alberta
    Glass calm at lunchtime so went out for 1 last slalom run, water @ 6* C, air @ 7 with some sun, had a nice boat ride after as well. Slipped a blow out ring on the trophy plus a while back. Breaks away even faster @ holeshot. Great season, motor ran beautiful, sitting at 672 hours now, will clean up the vst, replace the impeller, inspect the plugs again, [still originals] gear oil ect. Finally got the new 2 stroke oil I ordered from mercury racing - had a look at it, synthetic blend, red in color, seems like a lighter viscosity with a slightly different odor than the multi fuel oil I am using that had been recommended for the motor originally. This new oil is good for all 2 strokes and opti's, including the race models, motorcycle, snowmobile engines, air or liquid cooled, oil injected or pre mix applications. Part No. 92-8M0078011. The new 85W-90 gear lube for all racing outboard and stern drive gear cases showed up and appears different as well. Part No. 92-8M0078015. Glad I went today, snowing and blowing now.
  6. #306
    Jul 2004
    Connecticut
    Quote Originally Posted by xb03fs View Post
    The 200XS Gen 2 power head alone is $9,800 smackers?
  7. #307
    May 2007
    STL
    Dressed power head less ecu. That was msrp and implied dealers should sell for less than that
    [IMG][/IMG]
  8. #308
    Jul 2004
    Connecticut
    $9,800 + $2,100 for the ECU! For those numbers they should at least give a 1 year warranty.
  9. #309
    May 2007
    STL
    It should be sold for the same price as a 225 or 250 Pro XS and an optio for it to be on the 175 prosx mid, with the standard 2 year warranty from merc racing and they would sell more than they could build.. My boat can now handle a 3 liter but I would opt for the 2.5 for fuel economy. I only need to run in the 80's, I feel safer in the 80's.
    [IMG][/IMG]
  10. #310
    Discovery Bay, CA
    I'm surprised they'll even sell you a complete/dressed powerhead, you can't get a complete/dressed 3.2/300XS powerhead unless it's a warranty claim.............
  11. #311
    May 2007
    STL
    Quote Originally Posted by Rayzor View Post
    maybe the rep I spoke with was misinformed. I know they will not sell it on a 20" leg. Its out of my price range and no way a bank will loan on a powerhead only.
    [IMG][/IMG]
  12. #312
    Jun 2012
    Indiana
    I am curious as to what the price is on the SST version? Similar to the ROS model? Anybody know?
  13. #313
    Feb 2007
    lily lake WI
    The power head is the same the only difference is the ecu rev limiter sst 8000 ros 7000
  14. #314
    Jun 2012
    Indiana
    I was wondering what the price is for the complete motor, 12" mid, speedmaster, the whole thing?
  15. #315
    Jul 2004
    Connecticut
    Even if they sold the complete power head with ECU under a one year warranty I think they would have a decent number of buyers
