Page 12 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 166 to 180 of 357
Thread: new race models
  1. #166
    Oct 2009
    cold lake
    Your welcome, A lightweight powerhead bolted on top of HD components provides great balance to the overall package, something you can't help but notice when you start dancing through the rough stuff. The boats overall weight is carried lower, the hull is pushed from closer to the water, totally wicked advantages that become more evident/beneficial when pushing hard in rough conditions. Tough to pull this kind of ability/agility/balance from a data sheet. Every reason in the book the new RACE MODELS are based on the 2.5 powerhead. Bolt on a big block powerhead that weighs 60 pounds more to the same assembly- sorry advantage lost.
  2. #167
    Belgium
    Quote Originally Posted by Michael J Giesler View Post
    wow how about this i will be at merc racing in 2 weeks maybe they can put one on there dyno so everyone will quite gripping about 225hp or 200 or 240 how does that sound let's be greatful that there still is a lite weight motor to put on or ally's i know what they make because there has been one on a dyno not to long ago it was a champ 200xs power dyno not propshaft it's still a great motor i will also ask why no warranty also
    That's great! Thank you.
    As for the warranty I think it's obvious.Normaly this engine can only bought by racing teams. So that means the engine is going to be raced. Tell me who is giving a warranty for tstuff that is going to be raced with? I dont think many manufacturers will do this....
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  3. #168
    Jul 2004
    Connecticut
    Thanks Michael, that would be great info to have on the GenII
  4. #169
    Jul 2004
    Connecticut
    280 Dyno sheet attached ..........
    Attached Files Attached Files
  5. #170
    Jul 2004
    Connecticut
    And some specs from a 2006 GenI 200XS Owners Manual..........
    Specifications - 2006 200XS OptiMax
    Engine Weights
    15 in. (Sport Master) 197 kg (434 lb.)
    20 in. (Sport Master) 200 kg (442 lb.)
    20 in. (Torque Master) 197 kg (434 lb.)
    Gear Ratio Torque/Sport Master 1.87:1
    Full Throttle RPM Range 6000 -6500 RPM
    Required Fuel Premium Unleaded
    91 R+M/2 octane (96 RON)
    Recommended Oil Premium Plus TC-W3 2-Cycle
    Gearcase Lubricant Hi-Performance Gear Lube
    Gearcase Lubricant Capacity 666 ml (22.5 fl oz)
    Battery Rating
    1000-MCA (Marine Cranking Amps) 800-CCA (Cold Cranking
    Amps) 105 Amp Hours1
  6. #171
    Oct 2009
    cold lake
    Interesting racers are just changing to GEN 2 powerheads, MY understanding is only complete motors available for the ROS. conversion kits only for SST racers. Must have built some kits for the ROS as well. makes me wonder about the tuner?
  7. #172
    Jul 2004
    Connecticut
    Where is "Cold Lake" btw?
  8. #173
    Oct 2009
    cold lake
    Cold lake Alberta Canada is located on the Alberta- Saskatchewan border in about the middle of the provinces. Southern edge of the northern boreal forest,some of the finest freshwater on the planet. don't get me started. The ROS likes the cold water, has to be a hot day for temp to reach 100 when cruising or pushing hard.
  9. #174
    Sep 2006
    Quote Originally Posted by xsflight View Post
    Might be like you say in the states but here in Europe there is a ROS conversion kit available. Got one in the garage.
  10. #175
    Belgium
    I agree. I also found this on the Merc Website somewhere.
    There is a conversion kit for a XR2 to 200XS gen2.
    I wonder what the price is for the conversion kit and what comes with the kit?
    Fletcher 17F6
    Hydrostream HST 20F
  11. #176
    Oct 2009
    cold lake
    awesome brother you Will like it.
    Did you change your sticker? don't think GEN2 powerhead kits will be available anymore,complete motors only after this years batch!!! new tuner or not?
  12. #177
    Oct 2009
    cold lake
    Did the Gen 1 ss use the big vertical trim/tilt ram or the just the little horizontal trim ram?
  13. #178
    Jul 2004
    Connecticut
    Wait a minute, what is this conversion kit that our European brethren can get. Are there any more details on the GenII "conversion kit" ?
  14. #179
    Oct 2009
    cold lake
    Initially, I know a conversion kit was offered for SST-120 racers which included the complete powerhead,upper/lower cowls/tuner and SSM gearcase. Was NOT aware of a powerhead kit for the ROS, BUT was told about half of first batch of GEN 2's were complete motors, the other half conversion kits for BOTH SST and ROS. Was also told that this years preordered batch would be the last time kits would be available. complete motors only going forward.
  15. #180
    Oct 2009
    cold lake
    Real performance figures on these motors should include a comparison of fuel consumption at corresponding levels of output. Then we could measure, compare and access true performance. Any increase in performance and speed from previous models or other engines should be measured against the amount of fuel used to create the said output. 82.5 liters/hr at WOT. 259 total engine hours and 3842 liters of fuel consumed.
