Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Melted piston
    South Florida
    Melted piston
    I have a 2005 Merc. 2.5 Optimax xs, 225hp, on a 20' Hydrostream. The motor has 150 hours on it. The # 5 piston melted in the cyl. and disconnected from the connecting rod.
    My question is what would have caused this. I use Merc. oil, and 92 octane fuel?
    I dident thing this could happen to such a computrized motor. I would think the computer would have sent an alarm and or shut the motor down before melt down?
    Any thoughts or input?
    Oct 2003
    Sanford, Florida
    As good as these newer motors are , they can still have there moments . Sounds like it leaned out for one reason or another . When there turning in there upper rpm range ,it can be hard to notice a slight loss of power . So , if you don't reconise what's happening ,this is how it ends .
    Remember , the piston/cylinder started to feeling bad . He still had 5 freinds tring to drag him out to the party !
    Sorry For Your Misfortune !
    Rich Martin 018
    HAVE BATTERIES , WILL TRAVEL !!!
    South Florida
    Thanks,
    Oct 2003
    St Cloud
    There is nothing the computer can do to monitor injector flow or mechanical defects in the engine....trust me, I know lol!
    MORGAN CITY LOUISIANA
    sorry for your loss thats a great engine but over 5 years with only 150hrs id say it was fuel problem. #5 is 1st to go when lean out. jmo Todd
    Quit Hate'n and go test.
    Like Rich said something caused that "cylinder to lean out" causing a temp spike. Just currious what do the other five cylinders look like?
    May 2009
    catskill ny
    [QUOTE=RNM018;1901243]As good as these newer motors are , they can still have there moments . Sounds like it leaned out for one reason or another . When there turning in there upper rpm range ,it can be hard to notice a slight loss of power . So , if you don't reconise what's happening ,this is how it ends .
    rich are you one of those friends that drags the hurt friend out untill he is stuck to a wall or floor party on, youll be all rite,
    1990 hydrostream virage diamondpower280
    Oct 2005
    Long Island / South Shore
    water in the gas ,junk in the vst ,bad fuel or air injector ,loss of low psi fuel pump
    any of the above and BANG its all over
    03 j17 skiff 40hp
    79 action 17 2.4
    79 15 viper (sold)
    85 22 velocity 225efi(sold)
    82 31 sea ray
    It does'nt have to be lean, I've seen many that the fuel injectors flood on. They soot up the top of the piston with carbon. Then you have what they call "an uncontrolled combustion event".
    Aug 2003
    Gilbert Arizona
    I'd rebuild it and sell out for a staight EFI.
    With the fuel situation these days letting any motor sit for an extended time without use is not good. Constant use of fuel stabilizers is an absolute must along with regular injector service.
  12. #12
    South Florida
    Thanks for all the input. The other cylinders look fine. Only # 5 has a hole right in the center of it.
    I hope to get the piston out and check the block (keeping my fingers crossed). I was told it could be resleeved if thats the only damage (knowing my luck thats not the case)
    How hard is it going to be to get parts for this engine being its "Mercury Racing" and how much more $$$ then stock? Worst case a new power head?
  13. #13
    Aug 2003
    Gilbert Arizona
    I never ran any gas over 2-3 weeks old,stabilized or not,would pump it out and run it in my truck.
  14. #14
    Quote Originally Posted by Greggw/2g's View Post
    They are not a hard engine to rebuild, just time consuming. There are aftermarket, oversized pistons on the market as sleeves as well. The real cost comes in the servicing of the injectors, pcm and compressor to find out WHY it stuck. The air injectors are near 400 dollars a piece, and the fuel around 180 if any need replacing.
  15. #15
    Dec 2001
    And That's No Bull
    All the save gas motors cost in the end. I think I will have a nudda.
