Results 1 to 15 of 20
    Nov 2003
    Saint Inigoes, Maryland
    Hydrostream HST - Set-up/prop recommendations?
    Bought a 1989 Hydrostream HST in Oct 07' with no engine. The boat needed some interior work...so, bought a new set of bucket seats for it and had an old 200hp Evinrude crossflow (20" leg) leftover from another boat lying around so I mounted that on a 12" Slidemaster manual jackplate with a 6" Slidemaster hydraulic jackplate behind that, giving me about 18" of total setback. The crossflow had no LWP on the lower and no temp or water pressure gauges hooked to it (my fault) so I fried the block. I have since purchased a 200hp Mariner outboard (25" leg) hooked-up temp and tach gauges. I'm currently running a 24pitch drag-cut chopper and at WOT motor turns right at 6000rpm's.
    My questions are directed at current HST owners..........1) what amount of setbacks are you running? 2) combined with what hp motors? 3) what height above the pad is your prop shaft when (trimmed and running full out) gives you the best top-end? 4) what type/size/pitch props have you had the best results with? 5) what kind-of top-ends are you seeing on (GPS)? 6) what improvements can I make to the hull/engine to get more top-end? I would appreciate any and all input....thanks.....
    Sep 2007
    Peterborough, Ontario, Canada
    18's of setback PLUS a 25' mid? Thats alot of stress on the Transom!
    "Brandon Field"
    Formerly Fieldzy
    Silly Rabbit, OMC's are for Kids
    1982 Hydrostream Vandal, Currently under Resto
    Sep 2007
    Calgary
    I Recommend...............You Used the SEARCH button
    89 charger-93 merc 2.5L 245hp
    Soon to be MAD EFI!
    JUPITER, FLORIDA
    Many HST owner's are running 10"-12" of setback with the prop-shaft 1/2 above the center pad. 18" is alot of stress on the transom and may be counter productive to topend speed...you may wind up burying the transom instead of creating lift (but I've heard of one guy running big setback (16+")on his HST with no problems so ????) The old Hydrostream owners site has some articles on HST setup and the guy reccommends no more than 6" of setup. Bare in mind that there is already at least 6" of setback built into the design of the hull. I will probably settle on 10"-12" of setback on my AE-21 when I finally rig the boat and beef up the transom knees.....
    J-Town Hot Boat Team
    Barracuda 188CCR/Suzuki 140
    Past Boats:
    Checkmate 2800SX/Twin Merc 250’s
    Checkmate Pulsare 2400/Verado 300
    Checkmate Starflite/Merc Pro XB250
    Canadian Edition Hydrostream AE-21/Merc 2.5
    Checkmate Pulsare 2100/Merc 225Xri
    Hydrostream Valero YT Bowrider/Merc 175
    Talon T-21/Mercury Racing 2.5 Carb
    Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
    Velocity 230/Mercury 454 Magnum
    Scout 172 Sportfish/Yamaha 130
    SeaRay F16 Jet boat/Mercury SportJet
    SeaRay 17' Seville/Merc I/O
    25 inch mid needs to go. Hst's vary in weight alot, more to do with how much water is trapped in the foam of the outside sponsons.
    With a 200 and a 28 hoss triton you should'nt need more than 10 inches of setback. And you need to get you lower coned and lose that x-long mid.
    Dec 2001
    SO CAL
    12" set back, prop shaft 1/2" above the pad, & a Yamaha drag prop.
    Hammer Down!
    Belgium
    Quote Originally Posted by Hammerhead View Post
    Hammerhead,
    What speeds are you seeing with a top end prop?
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
    Nov 2003
    HST set-up
    First let me say I appreciate everyones replies to my thread...(Mapleleaf) I realize 18" of setback is a lot of stress on my transom however, if you go to the Hydrostream website it states that "the HST transom area is extremely strong built to handle the added strain of the required setback recommending(a MINIMUM of 8"). It also states "setback will help with performance" which is why I initially installed the added setback. (Jupiter) I really haven't noticed the boat "burying the transom" that you describe. When I start to air the boat out (around 65mph) it seems to get-up on the pad nicely. I would like the web address you found that states no more than 6" of setback to see what other information it might provide? (Capt Insane) When I take a straight edge and come straight off the center pad back to my engine with my current setback with both jackplates (both all the way down) with my (25" mid) the water-line is about 1/2 way between my cavatation plate and prop shaft. Even with a low water p/u on the lower unit of a (20" mid) I don't see how the engine would get sufficient water??? I am going to take a hard look at the foam on the sponsons for water soaking, the boat (did leak at the rear deck seams when I got it) so I remove the rubrail and sealed both sides with 3M deck joint caulk and that took care of it. (Hammerhead) What brand of jackplate are you running and is it hydraulic or manual? What diameter and pitch is the Yamaha drag prop you're running? What HP is your motor? Is it a 20 or 25" midsection? Thanks again everyone for your input...
    Dec 2001
    SO CAL
    Bigboy I don't really have a good top end prop I have 24p copies it runs 92 mph with a good hole shot. My 26p Yamaha worked by R&R out Henderson Nevada runs A strong 97 mph. I have seen 102.
    Hammer Down!
    Belgium
    Is that a stock 260 you are running? How heavy is your boat?
    I think i saw some pictures of your boat doing some drag racing at an event.
    Fletcher 17F6
    Hydrostream HST 20F
    Dec 2001
    SO CAL
    Stang I do not know the brand of jackplate but it is manual my prop is 14" 26p I have a 240 hp bridgeport worked on by John Marles never dyno'd and a 20 midsection
    Hammer Down!
  12. #12
    Dec 2001
    SO CAL
    Bigboy I have never weight my boat it is not a race boat but it is lite. A chopper give me too much bow lift and not enough stearn lift
    Hammer Down!
  13. #13
    Belgium
    Good to hear yours is light mine is heavy as hell
    Fletcher 17F6
    Hydrostream HST 20F
  14. #14
    Dec 2001
    SO CAL
    Quote Originally Posted by bigboy View Post
    I have the orig invoice on this boat it states per John tiger the same seven color gel-coat as the power boat magazine performance report. There a lot of HST out there with the same 7 colors. I have only drag raced @ speed ally in Lake Havasu
    Hammer Down!
  15. #15
    Aug 2002
    Winnipeg, Canada
    You can hang a V-8 on an HST and not worry. The entire ass end is all tied in together.
    Hydrostream Venus
