Results 1 to 12 of 12
    May 2006
    dunedin new zealand
    Bridgeport sleeves
    I am neeeding to know a good supplier for a bridgeport sleeve. Do LA sleeve or advanced sleeve have the edges of the port angled to suit gas flow? or are they cut straight?
    also, does anyone do an aluminium nikasil plated sleeve that i can put in?
    What is my best option?
    thank you
    Sep 2002
    Panama City Fla.
    We stock both LA and Advance sleeves for Bridgeport engines. We have also have had Nikasil sleeves made for the same application. The steel sleeves are FAR less expensive. We also offer new Wiseco pistons machined for BP use.
    www.eagleoneperformance.com
    Feb 2003
    clinton,ia
    how much does it cost per cyl to sleave? i have a bridge port block laying around that im not sure what to do with. thanks
    May 2006
    dunedin new zealand
    whats the cost for both and do la and advanced sleeve have angles cut on the ports for a good gas flow or are they machined straight?
    Jul 2002
    FT WORTH, TEXAS
    sleeve
    It's around 250.00 in this neck of the woods
    May 2006
    dunedin new zealand
    does anyone have an ideas on advanced or LA sleeve? about the angle cut on the ports or do they machine it straight through with a 90* step in the top of the port?
    Jul 2002
    FT WORTH, TEXAS
    It"s
    Called a flanged sleeve a good machine shop will run a ball hone in the hole at that point to help remove those ring snatchers but cuttingza bevel on them ports if thats what you mean????
    May 2006
    dunedin new zealand
    no i mean the holes cut in the sleeve (finger ports and bost ports)are the top and bottom edge cut with a angle to aid gas flow or dose the gas hit a sharp edge as it flows through?
    Southern Maine
    LA is straight cut. I always use Advanced. The are angle cut and the ports line up alot better then LA. Especially in the bridgeport. Basically less grinding you have to do after you install the sleeve. The last LA I used was about a month or 2 ago and after seeing how far it was off I took it out and put in an Advanced.
    May 2006
    dunedin new zealand
    great help thanks black lightning.
    Jan 2005
    New Zealand
    Try Steve Pope at Steve's Marine in Cromwell. He ran 2.4L engines on an F1 boat for a number of seasons (I assume you are talking about 2.4L bridgeport?). He may still even have a damaged block that you can cut the sleeves out of???
  12. #12
    May 2006
    dunedin new zealand
    thanks . yea i know steve this is his old motor. good idear i might try to find a old block.
