Results 1 to 11 of 11
Thread: OMC Tach Wiring - Johnson RS
01-11-2010, 01:29 PM #1
Does anyone know the wiring for this tachometer? (P/N 387666 written on box) This is a 10K tach I intend to use with a newly restored Johnson RS V6
Thanks!
Roger Hinsdale
http://i438.photobucket.com/albums/q.../Tach-back.jpg
http://i438.photobucket.com/albums/q...Tach-front.jpg
http://i438.photobucket.com/albums/q...onRScvr2-1.jpg
01-13-2010, 09:51 AM #2
OMC (vintage) Tach Wiring
Talked with Racer (Al S.) and he thought this type of tach only required the "gray" trigger connection and ground (no +12V). There is a yellow and a white wire that exit the back of this tach (they are not for a light). Racer could not remember which color was the trigger or ground for sure. This is a 12 pole tach.
01-13-2010, 04:45 PM #3Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
White is the ground yellow signal
01-13-2010, 05:15 PM #4
Roger that thing looks frigan beautiful!!!!!
01-13-2010, 05:15 PM #5
01-13-2010, 05:44 PM #6
01-13-2010, 10:45 PM #7Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Those engines do have thru transom trim and built in up/down
01-14-2010, 02:22 AM #8
01-14-2010, 07:18 AM #9
It is very similar to mine Kevin.
Ló fasz racing
Joe Horvath
01-16-2010, 03:24 PM #10
RS w/Cvr off
Kevin,
Was busy, so didn't see your question about the trim. Racer answered anyway. I added this picture that shows the bracket assembly a bit better. I powder coated the LU black, so pictures don't show detail at all. The center pin is the up/down cylinder and there is the thru transom cylinder for tilt. Got to admit that I'm anxious(excited) about getting this motor running. It's by far the meanest outboard I've ever messed with. The real thrill will come when the Molinari is done with this beast on it. We figure the hull is a late 70's Molinari. Look out Vintage!!
Roger
http://i438.photobucket.com/albums/q...motorLF750.jpg
01-16-2010, 04:15 PM #11
that's one mean looking mutha. got any other powerhead pics?
Mike Dowling
