Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 15 of 82
    Jul 2004
    atlanta
    carbonfiber/kevlar layup
    after about 8 months of not working on the boat..I am back at it.
    It is going to be carbonfiber/kevlar layup with no core...what do you think putting down 2 layers of 5oz kevlar followed by one 5.7oz carbonfiber followed by 2mil coremat (in the areas the old core was) and then 2 layers of 5.7 carbonfiber? total cost on all that less epoxy is 550.00 I got a deal..thats less than screwing around with atc corebond and a composite core.
    I know the pros and cons but I want NO wood.
    I belive it will be lighter and a hell of alot stronger
    a pic of where I left off at...should I use 2mil or 4mil coremat?
    Oct 2009
    Tappahannock Va.
    Is that a stream with a concave pad?
    Jul 2004
    atlanta
    yes, vector... concave and hooked
    Most comp boats didnt have a core but they had 4 stringers
    Oct 2009
    Tappahannock Va.
    Quote Originally Posted by mrconcrete View Post
    What year ,and what kind of power is going on it?
    Mar 2009
    Port Saint Lucie
    I'm not a huge fan of the coremat, it yealds no strength it just absorbs resin. By its self it breaks like a cracker. (if its the same coremat that we used to make consoles out of) I would rather see you use 1/8" k-mat or something like that. Its the same thickness, but it is actually a foam core product. Just an opinion. With all the high tech materials going into it, the coremat would be low tech in compairson.
    I also agree with the stringer coment, with no core you'll need more stringers spaced closer together. The material your putting into it wont build up much bulk or thickness. I probably would go with a 1/2" scrimed and scored core. Kevlar,Kevlar,Carbon, putty,core,Carbon,Carbon,6or8oz finishing cloth. The cloth is so you can sand it smooth and not burn through the carbon. Carbon sands real real easy be careful
  7. Thanks Scott in MN thanked for this post
    Jul 2004
    atlanta
    Quote Originally Posted by Gorilla0178 View Post
    Thanks for the help...and yes I am putting in stringers kneebraces all the BS.
  9. #8
    Jul 2004
    atlanta
    Quote Originally Posted by kytekeith View Post
    77..300+ 12" mid ,1.87 sporty
  10. #9
    Jul 2004
    atlanta
    the more I think about it I will probably put a piece of corecell in instead of the mat.
  11. #10
    Mar 2009
    Port Saint Lucie
    Oh yeah corecell, the good stuff. Sounds like a plan.
  12. #11
    Jul 2007
    Have lived and worked in New Zealand ,Tahiti,Australia,Japan , south Korea, And now Suzhou in China
    Time for a little thought to go into what you are going to do . Number one NEVER USE COREMATT IN THE BOTTOM OF A BOAT ! ANY BOAT !!!!!REGUARDLESS OF THE THICKNESS AND WHAT RESIN YOU ARE USING !!!!
    Can use it in the topside but NEVER in the bottom !! core matt will not stand any kind of flexual movement for any great period of time . and will shear and separate . DONT DO IT !!!!!
    Kevlar has a lots of streach and wont let go . Carbon has no streach and will break before it lets go .
    You would have to deal with the carbon and the kevlar using epoxy resin and nothing less!!
    Unidirectional fibre would be my choice just the oriantation of the strands would be the critical factor to gain the max amount of rigidity and stiffness from it !!.
    If you not having a core in the bottom then a couple of stringers each side will do wonders for what are looking for as well as the carbon fibre as the final top layers and stringers over the top of that with some good double bias cloth to hold them in and down onto the carbon .
  13. #12
    Jul 2007
    Need to put the record straight here!! do you understand what corematt is used for normally ??
    Anyone know !!
    Im going to wait for a reply or two and see if anyone is on the right track and understands the properties of core matt and its uses !!
  14. #13
    wisconsin
    core mat is a stiffner .. used between 1808 etc.. make a sandwich type
  15. #14
    No core in a 300 hp vector...........wow.
    I'm sure the factory comp boats had a different skin lay up than the standard cored productions to toughen them up. The standard production boats skin is ass. I'd at least core the stressed running surfaces with some 1/4 composite something and the pad and inner areas with regular 3/8 or 1/2inch. I still don't see the facination of using carbon in a shell that is layed up like a ritz cracker to begin with.
    Running a non cored older 'stream with that kind of power is just asking to get your ass handed to you.
  16. #15
    Jul 2004
    atlanta
    the pad will be cored....it also is getting C/F directional tape put down first.
    I dam near have all the old chit ground out as whats left is paper thin anyway..hell I am down to the black gell they put down after the flake in a lot of areas..LOL
    If all the old **** peels off than at least I will have something left to ride in
