Page 7 of 51 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ... LastLast
Results 91 to 105 of 751
Thread: R/C helicopters
  1. #91
    Darien, GA
    hovering would be interesting
    That could get interesting fast
    Blazer VLX150 w/ 225 Johnyrude
    Hydrostream Viper (sold)http://www.youtube.com/watch?v=D0OA6oxZoTg
    Westwind mx15
  2. #92
    Jun 2004
    port st. lucie, fl
    Quote Originally Posted by Forkin' Crazy View Post
    IMO the Blade CP is one of the worst. I can fly an RC heli and can't fly one of those! Fly on the sim, then get one with a belted tail at the least.
    so its not me, lol!!! i gave up after crashing i don't know how many times!!
  3. #93
    Sep 2002
    The E-flite Blade mSR is going to get a lot more people into the RC helis. It's very forgiving, almost behaves like a coaxial, but give it some stick input, and WATCH OUT!
  4. #94
    God this brushless conversion im reading about is so tempting!
    i have also read about an upgraded tail motor but haven't seen one?
    Put the new tail motor on mine and i glued it so it wouldnt pop the cap off the back with the first crash, I also pulled the shaft through the prop till the prop was almost touching the motor (about 1/8-1/4in of the shaft sticking out of the tail rotor) so it couldnt push through the back of the motor. Seemed to work till it was crashed good a 20 times now the shaft poked through the back of the motor instead of the cap popping off... I thought i herd someone flying it, walked up stairs and my girl is on the computer smiling
    needless to say its back in the box and the batteries are elsewhere! Bulletproof tail motor mod in the works!
  5. #95
    Sep 2002
    I wasn't aware of any brushless conversion available for the mSR. I thought that stuff was too heavy for this one ounce bird? Why re-invent the wheel? The stock motor is already more than enough.
    I ran a bead of CA around the butt cap of the tail motor on mine as a preventative measure. No tail motor issues yet here.
    I DID manage to break the stock set of blade grips as most mSR pilots have done.
    I was ready for it though, as I visited the hobby shop earlier today, and thus had a spare set of grips on hand. I also cracked the landing gear near the front pin-- This is also a common injury. I built up some CA around the repair until I can get a new set of GLOW landing gear.
    Kevin, keep an eye on the little sleeve (below the grips) with the "goalpost" link guides. The posts can bend and make the links bind up between them.
    I may try to grind out a pocket on the base of the trailing edge of the blades to allow them to swing back farther into the grips during a blade strike. I read somewhere that this mod worked well. My factory blades are showing some wear (I have spares) so I might experiment on them tomorrow.
    This is serious fun.
  6. #96
    NE Louisiana
    If you can get them to flip around all the way, do it. Haven't looked at that yet. That is the way my larger helis are.
    I've been flying mine outside. Haven't perfected a hammer head yet, but I'm working on it.
    I got the hots for one of these right now. Doing research on the electronics. The new JR micro gyro looks killer. And should be right at home on this:
    Check out the head! And the tail!
  7. #97
    Sep 2002
    Wow, that looks pretty bad ass. Appears to run $440 with no radio, due out April.
    I guess that's the answer to all the forum posts of people wanting to own a palm-sized micro with the CP capability of their bigger machines.
    I ordered an aluminum grip head for my mSR today. Some say it makes the toilet bowl effect worse, but I've also heard the same about flying with excessive play in the flybar pivot point. Maybe one brings out the worst in the other? We'll see...
  8. #98
    NE Louisiana
    Main rotor diameter is about 18". You can get a std kit for as low as 160 scratch and dent, but it is not the SE. SE has all the alloy hardware and the kit is 230, less radio gear. I have a RX, I just need servos and the gyro.
  9. #99
    easiest way to keep your msr in one piece is hide the batteries!
    My blade grips look perfect, blades are scratched but thats it. My flybar is looking pretty oval shaped so thats getting changed too.
    that 250 is bad ass, thank god its way over my head
  10. #100
    Sep 2002
    Kevin, make sure to put a bead of Teflon lube between the mast and the flybar eyelet. This will reduce wear.
    The rest of the "ovalling" comes from hyperextension during crashes.
    I'm crashing way too much flying mine in the house, but the wind won't stop blowing and I'm afraid the freezing temps will make everything more brittle.
  11. #101
    Oct 2003
    New Jersey
    Quote Originally Posted by pyro View Post
    I was going to ask what to get, I assume I can learn on one of these and that if I crash it I can fix it cheaply???
    INXS
    88 Checkmate/Starflite/225 Johnson
    Member, The Paul Revere Society
    Always Live Life In Excess
  12. #102
    Oct 2003
    New Jersey
    OK how does the battery vrs gas compare? I would like a loud two stroke over a battery copter.
    INXS
  13. #103
    Sep 2002
    These have quite a steep learning curve. Start with something easy and forgiving, that doesn't break every time you crash. The MICRO helis like The E-Flite Blade mCX (co-axial rotors) and the Blade mSR (single rotor with tail rotor) are going to be the easiest to fly because they are stable and will allow you to learn how to control it while having some fun.
    You'd be crazy to get into a full-size heli, much less a gas-burner...
  14. #104
    Quote Originally Posted by INXS View Post
    I agree with Chad, you need to start on something very small and easy to fly, definitely electric.
  15. #105
    Oct 2003
    New Jersey
    "I agree with Chad, you need to start on something very small and easy to fly, definitely electric."
    OK where do the gas motors cut in???
    I would love to chase the pet deer out of the yard with one of those gas birds!
    INXS
