Page 18 of 51 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 ... LastLast
Results 256 to 270 of 751
Thread: R/C helicopters
  1. #256
    Quote Originally Posted by pyro View Post
    Stop watching it hover and start flying it and you'll never notice the TBE.
    It's not caused by electronics. Replace your flybar AND your links, seat the servo retainers tightly to eliminate the end-slop. The TBE will go away. It might also help to put a dot of CA on the shafts above them so they don't slip again.
    I never had a problem flying it before, now it is uncontrollable almost as if the remote has no effect. It went from hands free hover to TBE as soon as it leaves the ground something is WRONG there is no way to not notice the TBE unless its sitting on the ground
    Flybar is new ill try the links.
  2. #257
    That's a great video Chad - your flying is really good. Which camera are you using?
  3. #258
    Sep 2002
    I'm using a $15 keychain video camera taped to my hat.
    720x480
    30 frames per second
  4. #259
    I fixed it back in the air
    Here was the fix
    Verify Links are installed with "tooling" marks positioned away from balls
    (the Links eye's are bevelled on one surface, and "squared" on the opposite surface)
    (on the the surface that has the "squared" eyes, the Links have a "break-off" "tooling" mark in the middle of the shaft between the eyes)
    (Links must be installed with bevelled eye surface towards balls, resulting in the Link's "tooling" mark facing away from the balls)
    I guess i put two of the links on backwards at one point
  5. #260
    NE Louisiana
    Here was the fix
    I just looked at mine and one was backwards. . And broke the damn blade grip turning it around. My LHS still doesn't have landing gear.
  6. #261
    Sep 2002
    I broke my homemade landing gear today. I have a set of 'MIA' aftermarket skids in transit.
    I have the Microheli aluminum upper parts on mine.
    I modified my grip plate for more throw.
    As you can see from the video, it's insane.
  7. #262
    I picked up this new Falcon 40 to mess with and for training. I saw Chad had one, so I figured I would give it a try.
  8. #263
    NE Louisiana
    Here ya go!
    http://mikrokopter.de/ucwiki/VideoAbspielen?id=188
    And check out the GPS hold. Good surveillance tool!
  9. #264
    Sep 2002
    I flew my mSR into a sinkful of water today. Flew fine for 1 pack after drying out, then the tail started to misbehave. Now it has NO gyro function, tail always spins at the same speed. Grrr...
    Greg, I would have gladly sold you mine! Make sure to order extra blades, tail rotor, battery, canopy, and skids. They're only available through Xheli so get them while you still can. The Falcon 40 is an obsolete re-badged Walkera 4#. I've had some fun with learning to hover mine, but have only been flying the mSR lately.
    I'd recommend a nice, big garage floor for hover practice...
  10. #265
    NE Louisiana
    I did that with my CX2 and had to replace the RX/controler.
    May as well buy a BNF. The RX is 1/2 the price of a BNF.
  11. #266
    Sep 2002
    After the board dried out, the gyro started working again. Flew tonight in the house, with my newly shortened swashplate arms, and custom narrowed aluminum grip plate/head/guides. I can reallly toss it around now, I can do vertical stall turns indoors, but it's a bitch to keep the tail under control...
  12. #267
    Nice! I'm glad to know i can just dry mine out if it ends up in the lake when i fly in the back yard
  13. #268
    Chad, how did you set the flybar paddles on the Falcon 40? Do you keep them level?
  14. #269
    Sep 2002
    They're supposed to be level, but if you pitch them up 10 or 15 degrees to match the rotor blades, it will hover easier with better stability.
    The downside of angling the paddles is that it will slightly limit cyclic authority. When you graduate to flying outdoors in a slight breeze, you'll want to put them back level again. The Falcon 40 will have MUCH slower, delayed cyclic response that you've enjoyed with the mSR. You'll need to learn to stay a step ahead of it, much like driving a pad-vee bottom.
    Here's a custom mSR flybar I fabricated from a broken one. The shafts are .060 carbon fiber, and the paddles are thin hand-cut plastic, thinner and broader than stock. I experimented with different amounts of weight in the paddles for the best compromise of stability and insane cyclic response. I can flip it onto its head with NO weights in the paddles, but it's very difficult to maintain a steady hover. Too much weight makes it respond slower, like the stock flybar does. You can also see the CNC aluminum guides, rotor, and grips-- I've also narrowed the distance between the top link balls and shortened the swashplate arms. This heli is crazy now, I love it!
  15. #270
    Jun 2002
    Waterford, CT
    Thanks guys after seeing this thread in the AM, I went out and bought an MSR. Now I need six more 150 AMP batteries. Greg what are your local hobbie shop prices?
