Results 1 to 3 of 3
    Sep 2006
    250 pro xs coil falt code and runs bad ?
    We dumped boat in at this not so good ramp that has strong currents riping
    Ws just pulling away and moter quit . ready to hit a concrete bridge , I fired up kicker and avoided crash
    At 100 hours I lost a coil and a ecm . now i have 550 hrs and I lost all spark , found fuse blown , replaced fuse , runs but rough and has coil falty issue on smart craft .
    Is ths a comon issue with these ?
    can a guy pack a spare coil , restiance ck to find falty one ?
    Would be nice to pinpoint the bad coil and replace on the water to get home
    We get in some rough seas ect . and if the would have failed after we made it to our destnation . it would have taken 2 days to get home on our kicker
    Last time it took out the driver in the ecm that we diagnsoed here at my trans/auto shop with out the book or lap top , and my merc guy had same diagnose and repaired .
    I just ordered the merc shop manual cant talk to ecm as i have no soft ware
    I am suspecting a water intrusion on weather pac to coil causing fuse to blow , or a relay issue or is there some thing else on same circut causeing a issue to blow fuse ?
    Aug 2005
    Pembroke Pines , Fl
    bad coil's
    are common on the pro xs and all xs motor's in general, i would keep a spare on the boat. one shorted coil will blow the fuse and that means no start situation. you will need a multimeter, spare fuses and a coil...
    Columbia, SC
    buddy of mine has had 3 coils go out so far and its an 08 250 pro xs... so what ya know. Easy to replace but a bitch when u really need one to run in tournament
    JMO
