Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 106 to 119 of 119
  1. #106
    Oct 2005
    Houston, Tx.
    Quote Originally Posted by Mark75H View Post
    You are correct Matt, there are also some fairly modern Japanese made triples that are not yet listed
    3 cyl. Yamaha 50 ca. 1988.
  2. #107
    Feb 2011
    North Alabama
    Quote Originally Posted by smokin'joe View Post
    Missing the exhaust tuner (that means lost hp). Easy to get parts for the
    75.
    Race car has 3 tuned expansion chamber exhausts . Powerpack and coils are not shown.
  3. #108
    Oct 2005
    Houston, Tx.
    Quote Originally Posted by OldSchoolRestorations View Post
    Expansion chamber is clearly superior to stock tuning. Instead of powerpack and coils on the starboard side of the motor, plug wires are coming directly from the stator.
  4. #109
    Feb 2011
    North Alabama
    1975-ca. 1987 OMC 75, used in EP/SE classes, 49.9 c.i., or else .
    Joe' is the block the same as 1968 55 hp ??
    Oct 2005
    Houston, Tx.
    No. All earlier 3 cyl. OMCs had inferior porting, at the very least.
    That's a 1975 or later 70 or 75 block. A difference between the two
    is chamfering of the exhaust ports on the 75. The thinnest, lightest pistons
    were in the 1974 70. I have three, in my stock of about 35 pistons
    for the 75. Never tried them, was always too afraid of metal failure.
  6. #111
    Mar 2009
    Tulsa,Ok
    You have the greatest information, just want to say thank you!
  7. #112
    Oct 2005
    Houston, Tx.
    Thanks. Since you like my posts I'll add that I've known Paul since our NOA days
    1958-60. You should have seen the Scott 40 run on one of the first wooden Allisons.
    We bought them the next year and ran Mercurys (faster, but the Scott was impressive).
  8. #113
    Aug 2009
    fort lauderdale fla
ID:	233534Click image for larger version.
ID:	233533my old 15 inch sport e motor ran pretty good turned 8400 the hustler header helped and the nitrous helped more
    people got piss** getting steped on with a 3 cyl omc so I put that deacal on the hood
    4 cyl....3 by evinrude 1 nitrous = 4cyl..
    it was a goodride
    LET's RIDE !
  9. #114
    Oct 2005
    Houston, Tx.
    Quote Originally Posted by joelsob View Post
    it was a goodride
    When I was a kid on Norris Lake (Tenn.) fisherman used to say 'Mah Evenrude won't far'. So we followed suit. SST-45 rig, boat by Darrell Beaulier, motor and props by Joe McCauley
    (Houston, Tx.). Here in Tx. we go for 'Evenrude!'.
  10. #115
    Another great thread . You will have to ask DoktorC about this triple.
  11. #116
    Oct 2005
    Houston, Tx.
    Greetings Guys. Maybe Mark75H or one of you can identify this motor .........It is in an early 60's mid-engine racecar I have. ????
    Dave Perry OldSchool Restorations of North Alabama
    3 cyl. OMC, 1974 or later, with OMC snowmobile carburetors.
  12. Likes Mark75H liked this post
  13. #117
    Oct 2005
    Houston, Tx.
    No. The 1973 block is the same as the 1974 70. The heads and pistons differ from 1973 to 1974. The 1973-4 block can be converted to 75 hp by chanfering the exhaust ports.
  14. #118
    Nov 2003
    40hp Yamaha
    40hp Yamaha triple
    Attached Thumbnails Attached Thumbnails DSCF4984.jpg   DSCF4979.jpg   DSCF4982.jpg
  15. Likes FMP, goodride liked this post
  16. #119
    Nov 2003
