Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 119
  1. #91
    The differences between the 60 and 75 were very likely present in the 'Scott 60' that set the NOA unlimited record at nearly 52mph ca. 1959
    Definitely not in 1959.
  2. #92
    Oct 2005
    Talking
    Quote Originally Posted by Mark75H View Post
    Only out of curiosity: how can you know that? NOA was McCulloch's showplace, and J.C. Leatherwood was his McCulloch's main dealer/race effort in Tennessee. I would be surprised if the factory did not modify the Scott 60 powerhead used in the time trials. A stock Scott 60 wouldn't run anywhere near that fast on any boat.
    I was there, we raced NOA OPC 1958-60. At the 1958 NOA nationals in Nashville clamp brackets (or swivel brackets) broke
    on seven Scotts. McCulloch flew in replacements to Leatherwood's team. I could generally outrun all Scott 60s on light boats (123' Norris Craft) Norris Lake with my Mark 58A, I'd be the last to claim that the 40s and 60s that set NOA records were stock. Am pretty sure they weren't, there was never a motor inspection in OPC 1958-60.
  3. #93
    Oct 2005
    Talking
    Love that gearcase. Looks like a plumber's dream.
    Without going thru Peter Hunn's Old Outboard Book, the first 3 cylinder that comes to mind was built by Thor ... the predecessor to Merc
    1938 & 39
  4. #94
    Quote Originally Posted by smokin'joe View Post
    McCulloch used WOA as their "showplace" I don't think you can find a single ad mentioning a win at an NOA race ... but the WOA races are prominently mentioned.
    How do I know about the 60/75 stuff? Because I have a technical paper from McCulloch Research asking Champion Spark Plug to help them develop the cylinder head for the 75. The 75 parts just did not exist that early.
    You know as well as I do that all time trial record setters are disassembled and checked to be at previously supplied and approved (by the sanctioning body, not the manufacturer) factory spec. If the porting or compression vary from a regular motor ... the record does not go in the books.
  5. #95
    Oct 2005
    Sam,
    The motors, especially the unlimited class motors, were never torn down in NOA OPC after records. I'm going to post and send you a McCulloch ad listing their NOA records. At the 1958 NOA Nationals in Nashville they flew in parts, clamp brackets on 6-7 40s and 60s broke during the closed course race. The marathon nationals were next day.
    Best wishes,
    Oct 2005
    Talking
    Sam,
    Here's where you can see the Scott ad listing NOA records: pg. 131 of Hunn's "The Golden Age of the Racing Outboard". For those of us on the east coast, to a first approximation WOA did not exist. Recall also that McCulloch sent the twin powerhead hydro to Knoxville to try to break the NOA Class X Record.
  7. #97
    Here's the ad again. Other than Hunn's book, do you know where it was used?
  8. #98
    Oct 2005
    Talking
    Not offhand. I have the 1958-1960 NOA rule books in Houston, might have appeared therein. I think I saw it as teenager and (as my German wife would say) 'groused' and tried to forget it. NOA ruled my Dad's Aristo-Craft illegal for 60-70 class (he could have upped that record 4 mph to 48.5 mph), and he wasn't prepared to run 52 mph in unlimited. We ran strictly stock motors.
  9. #99
    Jan 2010
    New England
    I started taking one motor apart the other day, have you seen this done to the intake runners before?
Name:	culloch, house paintings 013.jpg
  10. #100
    Yes, its called stuffing. Its done to increase velocity
  11. #101
    Dieter Konig, son of Rudolph Konig ... added a cylinder to his 2 cylinder racer to make a 3 cylinder 30 ci racer
    The bottom carb is missing its float bowl.
    You may have noticed that my HRE did not have the original ignition or cylinder head.
    Well, I found an original HRE cylinder head. I've been wondering the whole time I've known about this motor whether it actually ran with the battery ignition or whether it was a work in progress that was never completed. Now I'm pretty sure it was run with the battery ignition ... when I removed the bottom head - the piston ring was imbedded in the head. The piston did not seem to be damaged, nor was the bore.
  12. #102
    Feb 2011
    North Alabama
    Greetings Guys. Maybe Mark75H or one of you can identify this motor .........It is in an early 60's mid-engine racecar I have. ????
    Dave Perry OldSchool Restorations of North Alabama
Name:	DKW Spare engine.jpg
ID:	227649   Click image for larger version.
Name:	DKW spare engine 2.jpg
ID:	227650   Click image for larger version.
Name:	DKW Spare Engine 3.jpg
  13. #103
    Oct 2005
    Old School Restorations
    Quote Originally Posted by OldSchoolRestorations View Post
    1975-ca. 1987 OMC 75, used in EP/SE classes, 49.9 c.i., or else is
    the slightly different 70 hp block. Ignition system is not OMC,
    powerpack and coils are missing. Has had other carburetors adapted.
    Missing the exhaust tuner (that means lost hp). Easy to get parts for the
    75.
  14. #104
    Oct 2005
    Quote Originally Posted by MattGreen View Post
    Sam, in the late 90's - early 00's OMC/BOMB made a small 3 cylinder - 25 & 35hp. I think they were made for about 5 or 6 years, in parallel with the traditional 2-lungers. The 3 cyl were legal in Sport C and at least a few Region 10 racers did use them.
    Matt
    The 3 cyl. OMC 25/35 was designed by Jim Nerstrom, and was produced mainly for the Italian market. Jim says the 35 is more like a 40-45 hp motor. They're rare in the U.S. and are not easy to find in Europe.
  15. Thanks odd1 thanked for this post
  16. #105
    Oct 2005
    Volvo/Crescent/Archemedes triples
    Just one of many V/C/A triples made in the late 60's & early 70's
    The "Tornado" version of the 55 with the smaller non thru hub lower unit
    Note the 1955-2000 OMC 25/30/35/40 clamp and swivel bracket system. McCulloch Scotts used the same system. 5/6
    shock mounts on a Scott 25, e.g., can be replaced by OMC 25/35 mounts.
