Page 1 of 8 1 2 3 4 5 6 7 8 LastLast
Results 1 to 15 of 119
    Three cylinder outboards ... pleasure & racing
    Without going thru Peter Hunn's Old Outboard Book, the first 3 cylinder that comes to mind was built by Thor ... the predecessor to Merc
    1938 & 39
    About the same time Rudolph Konig made a 3 cylinder 2 stroke radial motor in Germany that had a successful racing version
    Notice a cylinder pointing off to the left and another to the right at the back; the third cylinder faced forward
  3. Likes FMP liked this post
    Dieter Konig, son of Rudolph Konig ... added a cylinder to his 2 cylinder racer to make a 3 cylinder 30 ci racer
    The bottom carb is missing its float bowl.
    This motor was unique in its day, using the exotic "Curvic coupling" segmented crankshaft ... fully "tinkertoy" piece together construction. You could literally take the motor apart and remove the center cylinder pieces and reassemble it as a 2 cylinder or a single.
    Decades later OMC would use Curvic couplings in the prototype rotary race motors
    Another uncommon feature of this motor, there are no reed valves. The carbs feed up into the crankcase, timed by an internal disk valve called a rotary valve.
  5. Likes FMP liked this post
    Another "add a cylinder" twin to become a triple was Scott-Atwater's 40 hp ... becoming the 60 hp triple. Nothing exotic inside this motor, reed valves and a solid crank.
    In 1961 McCulloch, the sucessor to Scott-Atwater improved the 60hp triple to 75.2 and introduced a gearshift racing lower unit for it ... the 75hp "Custom"
    The differences between the 60 & 75 were piston & head shape, carbs and transfer port covers
    The 40 & 60 used a wedge shaped combustion chamber, the 75 uses a hemi shaped combustion chamber
  8. Likes FMP liked this post
    Crescent ... sometime division of Electrolux and Volvo in Sweden ...
    Introduces a 3 cylinder triple 30ci race motor
    No reeds or rotor for this motor, this motor uses "piston port" intake controlled by the piston skirt
  10. Likes FMP liked this post
  11. #7
    McCulloch introduces a rotary valve intake, full race triple
    If you look closely you will see that this motor has the rubber bushing vibration isolation steering connection yoke just like the fishing version in post 5 and timing marks on the flywheel
  12. Likes FMP liked this post
  13. #8
    The full race McCulloch triple is revamped with a better steering connection and minor improvements to the lower unit
    2 versions were now available ...
    the standard 63.25 ci motor ... the "630"
    and
    a destroked 59.9 ci motor that qualified to race in APBA "F" class ... the "590"
    If you look closely at this motor and compare it to the motor above you will see some subtle differences. The flywheel is thinner, the carbs mount closer to the rotor and the rubber mounted steering yoke is gone in favor of a hard connected steering bracket straight out from the top of the mid. This motor also has "overflow" & return carbs instead of floats.
  14. Likes FMP liked this post
  15. #9
    OMC introduces their 49 ci triple ... 55 hp
  16. #10
    Known only in Europe, OMC makes a race version of the triple with the "X-115" race lower unit
  17. #11
    Merc introduces a 3 cylinder 49 ci triple
  18. #12
    Dick O'Dea convinces APBA to put the gasoline burning version of the Crescent racer in its own Stock Outboard class and the Crescent is reborn after the full race alcohol version is obsolete
    The class was named "C Super Stock Hydroplane" but earned the nickname "Super C"
  19. #13
    Merc introduces the 650X full race motor with Super Speedmaster lower unit ... forward only, no reverse, no neutral
    This motor is not the 650XS
  20. #14
    Merc introduces the 650XS sport-race motor
    Advertised in the regular line up along side the rowboat motors and ski motors
  21. #15
    OMC "CC" and "RS" triples
