Results 1 to 7 of 7
Thread: How high without a lwp
09-09-2009, 11:06 AM #1
200 Merc on a Vector. Jp flipped so less than 2in of sb. Motor is bolted to the jp in the lowest holes propshaft running about 3in below. Right now I can't trim much before losing water preassure. I'm going to put on a lwp but what should I do until then?
09-09-2009, 11:11 AM #2Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
Block the top water intake hole on the case and see if that helps.
09-09-2009, 11:14 AM #3
no lwp
I would put on a set of the Merc water intake scoops that bolt on over you stock water intakes. Do a search on here to get the part number.
Steve
09-09-2009, 12:31 PM #4
09-09-2009, 12:40 PM #5
first things first what water psi are you reading running with ""no"" trim. 2nd what's the water psi with trim. you maybe well with in spec for water press when running / on plane.
allison xr2001
09-09-2009, 12:44 PM #6
You should need almost no positive trim. The propshaft should be near paralell to the bottom. I ran mine 1 1/4" below the pad, but that was pushing the limit.
09-09-2009, 01:14 PM #7
I'm at 3in below the pad right now. I'm at 5lbs at idle about 10 at 1500 and 16 at 5000. The impeller is fairly new,but I'll put a newone in it again. Also I found I had a pinched water preassure line, I'm going to run the boat tonight and see if thats the problem.
