Results 1 to 10 of 10
Thread: Mercury Optimax 75hp -->115hp
08-23-2009, 03:54 PM #1Junior Member
- Aug 2009
- Norway
Hi.
I`ve got a Mercury Optimax 75hp. mod no 1B480857. This was sold new in Norway in 2007.
I`ve been told that this engine can be converted to 115hp by changing the pcm unit and removing the air restrictor.
I need help to choose the correct pcm to do this convertion.
Is this really safe or will i kill the engine ? Where can i buy the correct part(s) ?
I`m also interrested in a smartcraft system to connect my chartplotter Northstar 657 to the engine.
Which parts do i need ?
08-23-2009, 07:17 PM #2Member
- Mar 2009
- De Soto, MO
- 90
Gear ratio in gear case is different too.
08-24-2009, 03:13 PM #3Junior Member
- Aug 2009
- Norway
I see. ..
Will this stop my project here ?
If everything else is ok, i mean . . .
What will this do then ??
08-24-2009, 07:18 PM #4
There is a company in Italy that does Optimax PCM mods. I would check with them first. There is a link on my links page. (See below this post)
08-27-2009, 09:24 PM #5
It works great.
01-02-2010, 11:51 AM #6Member
- Jan 2006
- Cleveland, Ohio
- 41
01-03-2010, 09:25 PM #7
Give me a call and I will go over your options. 760-440-9334
02-04-2010, 05:50 AM #8New Member
- Feb 2010
- sweden
Have a look on: www.lundinsmarin.se, sweden, eskilstuna,
02-12-2010, 05:34 PM #9
the block, comp pump, pcm and fuel pump are also diff. too costly. you would better off selling and buying a 115
Quit Hate'n and go test.
02-18-2011, 12:54 PM #10New Member
- Feb 2011
- FL
Optimax 75, Did you Upgrade your PCM? Is anyone selling a PCM for a 2006 Optimax 75?
Hi everyone, just need a 2006 PCM for my 75hp Optimax. Can anyone tell me where i can buy a used one or a new one that i may be able to afford? Thanks very much.
