Results 121 to 135 of 156
01-07-2018, 05:08 PM #121
You are the one that regurgitated a 2 stroke with no intake valve, I just pointed out that the info/research is not new, I first learned about it from Jennings. You probably forgot about reading it there.
You probably can read it quicker than you think, no "muttling" because now you actually understand what you'd be reading ... and it might make some of what you know clearer or possibly easier to explain/convince others of your points.
AZMIDLYF liked this post
01-07-2018, 06:24 PM #122Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
01-08-2018, 12:09 AM #123
OwwwuuYaaamanZeeta ,
I see old school 2 stroke havin :
Inlet
Crankcase
Transfer ports
Exhaust port
Piston used to control port timing
Exhaust system
New school 2 stroke :
Inlet
Crankcase
Transfer ports
Exhaust port
Exhaust system
Major difference :
A dozen empty cans MunkhlinBeerinHutzlDrunkinHouzin
The video's were just as humorous . I liked how the motorcycle fired off with a turn of the wheel , idled perfect , no fuel stand-off .. LOL Turn the camera to his face , let me find a flashlight .. look in here ... wait , carbon monoxide is killing me .. ok now that I had time ... look in here ... Yea , OK .. that was quite scientific in discovery .. I'm so happy that you and he are both so impressed ..
Fong , @ least your spoof had some fuel stand-off . ( too much rotor cut ATDC )
And really nice try , but lets follow the time stamp in the lower left corner ....
2:38 instead of having a light set up and just roll the motor over .. your going to take it apart for us ....>
2:40 while your doing your best to convince everyone to look at your right hand ... you lose credibility by lowering you left below your waist ...>
2:42 No need in liftin your left now , you already got cracked ...
Naturally , when you run your next outboard "eng" in front of me with no reeds ..
I'll be the first to admit I was wrong .....
powerabout liked this post
01-08-2018, 09:28 AM #124
01-08-2018, 12:24 PM #125
the only 2 stroke motor that still has a change in hell to make it to market
https://www.realcleardefense.com/201...my_297376.html
powerabout thanked for this post
01-08-2018, 01:52 PM #126
Or maybe this??
https://www.google.com/amp/s/www.tec...onsidered/amp/
01-08-2018, 01:57 PM #127
That is the same opposing piston engine
01-08-2018, 02:01 PM #128
My bad lol, iiim aaa liiitle slooow
01-08-2018, 02:17 PM #129Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Yamaha is selling new 2018 two stroke outboards, Enduro series, 90* V4 1700cc 115hp and others, 2.6l 200hp.
01-08-2018, 03:16 PM #130
01-08-2018, 03:21 PM #131Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Nope , on the global commercial site. Tillers too for the v4. Carbs and premix, even a kerosene series up to 40hp. All blowingdown , scavenging and pulsing to manufacturers design.
01-08-2018, 06:52 PM #132Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
01-08-2018, 06:59 PM #133Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Product description for the Yamaha says stronger rollers, crankshafts and blocks for extended continuous use.
01-09-2018, 10:05 AM #134
Dave ,
There is no reason to hate anyone . And I certainly don't hate you .
At the World Street Finals in O-town there is/was an ol black man who set up a "three card shuffle" game every year . I'd watch a few hands , skip the voluntary faints and movement's and concentrate on the involuntary ones . Drop my $20 on the table , pick my card and walk with $40 . If I happen to lose my $20 , I'd still walk . We both knew who each other was and each treated it like it was a $100 hand because that was it until next year . Not enough at stake to get mad about .
You posted a video . I could have smiled and walked away . I chose to drop my $20 on the table . No big deal either way ... It's just a game
Two Strokes :
The whole premise of their existence is simplicity of their design . Good power for their weight and when operated within their physical limitations ... rather reliable .
While there certainly is room for improvement , which will come about by dreamers and free thinkers .. most seem to go down the path of complexity , adding weight and making less power . Millions are spent to save on a few cents worth of fuel. The ends never seem to justify the means , and good idea's get squashed along with the bad .
Professor Laureate , speaks with common sense about how the farce and how it came about .
As far as the crankcase goes for the common man :
The inner crank cheeks dictate the width of the slot on the reed side . How long it is on each side comes about during the mock up stage .
The rod slot side has a little more leeway . Some like to funnel into the upper portion and use the floor as the outside wall of the port . Others like the funnel on the floor side .
I just go off the premise that it's difficult to bend a column of air and keep it uniform at the same time ...
For those with a little more fire and a little less patience .....
Same fire a little more humor .....
01-09-2018, 06:52 PM #135Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I cant see any explanation of the coanda effect in a tube, just a mention only
