Results 1 to 9 of 9
    Nov 2003
    Saint Inigoes, Maryland
    Water temperature guage
    I have a new-in-the-box Mercury/Mariner temperature gauge kit. In the parts and instructions it provides and shows a single brass temperature sending piece to be installed on the head but, my engine already has a a wire that runs to each head to read engine temperature? Does anyone know the solution (hook-up) wiring procedure for a temperature gauge to my engine? My engine is a 1989 (200hp) V-6 Mariner Outboard.....any help would be most appreciated..
    Nov 2001
    South Carolina
    Leave the temp wires where they are. The sender with the gauge uses a mount that goes under a water jacket bolt.age is to be installed against the block. The senders in the block are for overheat warning.
    Never argue with an idiot. They drag you down to their level, then beat you with experience.
    3 X APBA Formula V Nat'l Champion
    APBA Formula V US-1
    It took me 29 years to become an overnight success.
    Sep 2006
    Minnesota
    My V6 has a sender in each head. One if for the overheat alarm, and the other is for a temperature gauge, and is wired all the way to the dashboard even though there isn't a temp gauge installed.
    To fish or not to fish? What a STUPID question.
    Nov 2003
    Temp gauge wiring for my 1989 200 Mariner V-6
    So if the wire from the motor goes all the way to the dash which wire out of my harness hooks-up to the temp gauge? What other wires would also need to go to the temp gauge?
    Sep 2006
    Minnesota
    Quote Originally Posted by 15 Mustang View Post
    Purple keyed power, ground, and lights.
    Sep 2006
    Minnesota
    There should be a diagram with the gauge. If not, there's one in the maintainance manual.
    Aug 2009
    new york
    Do you have a part #for that kit is it numbers or cold to hot thanks Dan
    Nov 2003
    Simi Valley, SoCal
    Temp should be tan but I don't have the book with me.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
    Dec 2004
    Massapequa, N.Y
    yes, tan is the temp wire It was any way on my 1990 200.
