Results 1 to 13 of 13
    Apr 2002
    Moselle, MS
    Mercury 250XS- 20" with Sportsmaster
    I have a 2007 Mercury 250XS with approximately 100 hours. It is on a Bullet 20XF boat. This is a great motor and a great boat but the two just do not go together. it is just too heavy for this boat.
    The motor is clean.
    Asking $10,900 or best offer call 601-319-9970-
    If you need smartcraft rigging harness, oil tank, smartcraft gauges, and engine harness, I can hook you up with that too and save you big dollars on this stuff.
    Here are the parts that I have for rigging with the Smartcraft setup:
    These parts listed for over $1,800 when I bought them. All for $1,000. if you can't use the Binacle control take off $200.
    ****Mercury Killswitch & Lanyard PN# 87-19674Q2
    ****Mercury Fuel Sender- fuel tank level for Smartcraft gauges PN# 851052Q (adjusted for 12" deep tank)
    ****Mercury Smartcraft Tach & Speedometer PN # 79-879898K1
    ****Mercury 3.0 L oil tank with sender PN# 8742A21
    ****Mercury Smartcraft Tachometer Harness* PN# 84-879979T1
    ****Mercury Smartcraft 4 way junction box PN# 878492K14
    ****Shifter control- forward reverse lever- Binacle shifter PN # 883711A12
    ****1 -Mercury Platnium cables- shifter & throttle PN # 883720A15 15' length
    ****Mercury Harness-key switch/engine harness PN# 896537K20
    Thanks
    Gary
    Apr 2002
    Moselle, MS
    Dec 2003
    rockford ill.
    how heavy?
    Under 500?
    Dec 2003
    rockford ill.
    how heavy?
    Uder 500?my guess would b 450pds.
    Jun 2001
    West Haven, CT
    Apr 2002
    Moselle, MS
    weight
    yep, 505 is what Mercury says which is dry weight. BWB tested this engine and the wet wieght was around 525 if I remember correctly.
    Dec 2008
    Bayou Country La.
    motor
    i got a 260 thats getting a over haul rite now... new nic,6 pistons,new 5petal front, s3000 chest cut, and a shaved head job, 20in on a sportmaster... looking to maybe get into a opti xs.. wanta trade?/
    Apr 2002
    Moselle, MS
    Quote Originally Posted by Im2fast4uracing View Post
    That sounds like it will be a great motor. but for this boat and the way it is used that would not work. but thanks for the inquiry.
    Gary
    Apr 2002
    Moselle, MS
    250xs
    The potential Canadian buyer could not get his deposit back on a new motor so this one is still available. We had a compression test done with 117 to 120 on all Cylinders. This is the run out on time and RPM:
    101.4 total hours as follows:
    18.8 hrs @ 0-599
    16.1 hrs @ 600-1499
    16.9 hrs @ 1500 - 2999
    12.8 hrs @ 3000- 3499
    10.8 hrs @ 3500 - 3999
    11.2 hrs @ 4000- 4499
    8.1 hrs @4500- 4999
    6.0 hrs @ 5000-5699
    .9 hrs @ 5700 up
    email or call me
    Thanks
    Gary
    Thibodaux.La
    I'm gonna say Mississippi.
    Apr 2002
    Moselle, MS
    gears
    Quote Originally Posted by jr britt View Post
    what state is the motor in, and is it 1.75 or 1.65 lower unit
    Its a sportsmaster lower unit with 1.75 gears.
    Location is Mississippi
  12. #12
    May 2008
    australia
    hello
    I sent a pm
  13. #13
    Apr 2002
    Moselle, MS
    motor is off the market
    Well, thanks to Jerry Jaco at Jaco's Marine we found a prop that would work with the 20XF. He recommended a 28 pitch Bravo 1 with 1 and 1/8" holes cut in the prop. The prop was purchased and Jaco's had the holes drilled. We got the prop in today (Thursday the 27th) went right to the lake and WOW what a difference. Great hole shot and very little slip and great lift and mid range and top end.
    So the 250XS is staying on the Bullet 20XF.
    Thanks for all the inquires
    Gary
