Results 1 to 7 of 7
    May 2009
    Bonneau Beach, South Carolina
    87 Ranger rigged for Yamaha going to Suzuki Help
    I have a 87 ranger fully rigged for a yammie. Motor did not come with the boat. I have a Suzuki 115 that I want to put on it. Economy is rough price was right on the Suzuki. My question is do I have to run all new cables? (steering, shifter, and throttle). I have tried to find an adapter I was told that they make them. Any help would be appreciated. I hope to hear that the yammie cables will work with no probs. Thanks in advance guys
    May 2009
    By the way the Yammie was a mid 80s 90hp The Suzuki is a Early 90s. Thanks guys
    Nov 2001
    South Carolina
    Cables will be the same. Adapters on end of cables may be different. Most use 33c type cables. Steering cable doesn't change for any brand outboard although the drag link will.
    Never argue with an idiot. They drag you down to their level, then beat you with experience.
    3 X APBA Formula V Nat'l Champion
    APBA Formula V US-1
    It took me 29 years to become an overnight success.
    May 2009
    Quote Originally Posted by Jeff_G View Post
    Thanks Jeff , Can I buy different adapters for my yammie cables that are on it? If so maybe you could steer me in the direction of where I can find them. First time brand swapping and I am confused
    Nov 2001
    South Carolina
    I think the cable adapters are the same.
    APBA Formula V US-1
    Gothenburg, Sweden
    Suzuki uses standard 33c cables just like Yamaha. If you were getting a Mercury, you would have had to get an adapter, but with the Suzuki there should be no difference.
    May 2009
    Quote Originally Posted by Markus View Post
    thanks for the info
