Results 1 to 6 of 6
Thread: I have a vibration
06-20-2009, 11:36 PM #1
I have a vibration
I am running a 95 four seater ( heavy lay up) mirage with a stock 200 2.5 liter Mercury. 8" rapid jack with a 20" leg. I have two prop a big ear 14 3/4" X 30 pitch hoss copy and a 28 pitch chopper II. Also 1.87 - 1 gears with a cle that was worked by Steve Smith.
From 40 to 75 MPH the boat is vibrating a little. I can feel it in the stearing wheel and i have hydrylic stearing. You can also kinda hear it as well when you are running. This never happened before. Happenes with both props. Once i get past 75, i don't feel it, not saying that its not vibrating. Just started kinda out of the blue one day. When it started, i was running 1/2 " over the bottom so i dropped the motor thinking maybe i was to high up with two people in the boat. Went ride today and i split the bottom and ran the 28". Did the same thing, if i trimmed high or tucked the motor. Checked the prop shaft and everything else i can think of and everything looks great. No water in oil and i don't think an internal bearing would make it do this. Any extra help would be appreciated.... thanks guys.....Eric B.1995 mirage jaguar w/ 200 merc....96mph @ 7300 rpm...... sold
1991 Allison XB2002, 1996 225 Promax...... sold
1998 Rocket DC w/ 2020 Yamaha Sho flashed
06-21-2009, 07:33 PM #2
to the top......
06-21-2009, 08:05 PM #3
I know when I run cleavers above the bottom, they will make the whole boat buzz with vibration. Try a 4 blade. If it goes away, then that's your problem. It vibrates because the blades are slapping the water
Boat Delivery available
Things owned. NOTHING!!
06-23-2009, 05:22 AM #4
"Check the flywheel"- as in loose? Ha ha. It better not be.
Steve also said something about surface running vibration. I am not counting that one out, it's just I ran it before at 3/4 above bottom and it didn't do it. Now no matter how high or low I stick the motor it does it.
The only thing I noticed different lately is that my motor twists more with the torque. Was thinking of sliding a torque tab on the skeg. Been thinking and not exactly sure how the torque tab works. The motor is twisting as if I was turning right. That's at low speeds. (0-60). Didn't get the balls to turn around running faster yet and look. Sounds about right? Thanks.1995 mirage jaguar w/ 200 merc....96mph @ 7300 rpm...... sold
06-23-2009, 12:20 PM #5Bud Conner "Heathen" "Defending Our Constitution"
06-23-2009, 05:59 PM #6
Have solid mounts and solid stearing. This issue is happening with the motor splitting the bottom or 3/4" over. Putting a torque tamer on tonight and run it tomorrow to see if that's the problem. I'll just run it till it blows if I have to.
