Results 1 to 3 of 3
Thread: 93 stv euro
05-30-2009, 06:06 PM #1New Member
- May 2009
- ontario
93 stv euro
Hi, I have a 2004 merc 200xs short shaft I would like to put it on a STV Euro. Will it work? Can anyone help? Thanks.
05-30-2009, 06:17 PM #2
yes if the transom is the 15 inch transom.If not then you will need a 9-10 inch setback (I believe) because when they build these boats they have to know what your engine hight is going to be.The standard transom is for the 20" motor.Or you can have a qualified fiberglass shop cut down the transom and then you can run the 15" motor without all that extra set back.The problem lies in that the steering gets in the way and you cant trim the motor
Rob Lankford
1988 20' Action Marine 2.4 200
Previous owned boats worth mentioning
1976 17' Action Marine 2.4 200
1984 20' Action Marine 2.5 200
1983 17' Hydrostream V-King 2.4 Bridgeport
2003 LPB STV RR COPY 2.5 280 /300 Drag
2005 LPB STV RR COPY 2.5 280
2005 Baja 23 Outlaw 6.2 Mercruiser
2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
2009 FTP Quarter Shot T3 Race 2.5 280
05-30-2009, 06:46 PM #3
Hydrodynamics makes a jackplate so you can run a 15 inch motor on a 20 inch transom. Here is one that was for sale a while ago.
http://forums.screamandfly.com/forum...d.php?t=157355
