Results 31 to 45 of 51
  1. #31
    Prince George B.C. Canada
    Quote Originally Posted by The A Dog View Post
    Haha! I never thought I'd hear such wonderful words. You guys are the best! It's like a huge weight has been lifted...so she's not dead (yet, lol)!
    See now ya know for sure. Make sure you by the good gaskets from merc. Mine are 60 bucks for two so your are most lickely the same or less. In the patern bring the bolts to 20 first all the way around in sequence. Brush or with a qutip put a little light oil on the threads and top part of the bolt first. Your two stroke oil will work.You get a true tourque that way with less resistance. After they are all snug to 20 bring them the rest of the way slowly in order, not to fast because your threading stainless into aluminum remember. Make sure the right touque is used for the other bolts you but back on also and your good to go. Run some {seafoam} threw the gas with your oil. That will help clean the piston tops up of all that oil deposit from running to rich. It will smoke a bit but thats just the oil loosening up and burning threw. Treat your motor to a nice lunch and run some higher octain threw for a tank. or always.91 or 94ish what ever ya got there. By the sounds of it also theres a product called ACES you might want to run. In the search theres good reading on it. I just ordered some myself. Its sounds like great stuff to run all the time. We,ll see. Im happy for you. Dont be surprized if things arnt perfict right away. Just take her for a good run and let things get back to tempature and hopefully your good to go once it gets fed a proper diet.
  2. #32
    Miami, FL | Hudson, OH
    Awesome! Do you use any kind of gasket sealing compound with new gaskets or are they just mated together by the torque on the bolts? Thanks for the tips, I will definitely treat her to Seafoam, higher octane, and read up about that ACES.
    Tough times never last but tough people do.
    1981 Baja 170SS | 1985 Mercury 150 2.0L V6
  3. #33
    Gibson louisiana
    Thats a good lesson read some of the post. First things first check compression first, spark next,then start woundering save alot of time.
  4. #34
    shreveport,la
    gasket ?
    no sealing compound. the gaskets should be labeled with "block side". make sure thats facing the right way. do just like whipper said to put the heads back on. definitely run the seafoam through to clean that motor up some. glad you got out so easy. and ditch the oil injection
    Erik Kiser
  5. #35
    Quote Originally Posted by patchesII View Post
    Glad you got lucky.
  6. #36
    May 2005
    ClamTown N.J. exit 58
    Adog i just brought in a set of Head Gaskets from my shop.
    The Quicksilver Part # is 27-41245 And the best part is There free to ya just pay shipping and These gaskets are the Improved package-unlimited shelf life!Genuine QUICKSilver.Now i dont have my Parts manual i lent it out and the little weasel isnt home so someone will have to look these numbers up to double ck on the application!One of my Scream & Fly brothers on here will have a book.Glad it worked out for ya now lets get her back in one piece and go flying! after we get a confirmation that the head gaskets are correct pm me your addy and i will ship them out asap/
    A.T. Godfrey
    Tuckerton
    N.J. USA
    2005 280 Ros 15"
    HydroStream/Ventura 16`
    Mercury 2.4 litre
    31`11" CC Scorpion pair 200hp Mercs
  7. #37
    May 2005
    A.T. Godfrey
    Tuckerton
    N.J. USA
    2005 280 Ros 15"
    Mercury 2.4 litre
  8. #38
    May 2005
    A.T. Godfrey
    Tuckerton
    N.J. USA
    2005 280 Ros 15"
    Mercury 2.4 litre
  9. #39
    Oceantraveler that is real generous of you taking the time to grab those gaskets and post pictures! That's cool, you have your own shop? Well let me know if your parts manual has made it's way home yet. I searched that part number on google and most pages that came up talked about it fitting 200 Mercs, but I'm not the expert so I'll wait to see what you guys find out! Thanks again for all the help, I'm real excited to get her on the water again. I've got boats on the mind...I even had a dream about boats last night, lol!
  10. #40
    Sep 2006
    Minnesota
    Yep, ya got the diseeze. That's one of the symptoms.
    It's uncurable. Support costs are all your disposable income, some of the indisposable income, most (useless) non-boating relationships, a lot of both waking and sleeping time, etc.
    Other symptoms include almost unbearable pleasure while sacking OMC's.
    hope it helps
    John
    To fish or not to fish? What a STUPID question.
  11. #41
    Sep 2002
    Yes, and it only gets worse.
    For me, it started with the same basic setup as you've got:
    '87 Baja Sport 170 (aka 170SS), '87 Merc 2.0 150 XR2.
    My first boat:
  12. #42
    I'm pretty sure some cylinders and pistons are scored...she can't even get onto plane anymore. Is it even worth a compression test? Won't cranking it with badly damaged pistons and cylinders score them even more?
    The engine: 1985 Merc 150 V6 outboard s/n: 0A181487
    Its downfall: Lost oil injection on the lake, didn't have enough extra oil onboard for the right premix ratio (I dumped about 3/4 of a jug into 15 gallons of fuel when the oil injection warning came on).
    How much do you guys figure a rebuild should cost?
    Check that serial # again.
  13. #43
    Quote Originally Posted by j_martin View Post
    Ahh haha yes, I'm seeing this now...just yesterday I was thinking the next girlfriend will have to like boats, lol. I took my ex out when we were still together and I had just gotten the Baja...all she could say was it was too windy and bumpy . Anyway, what was that definiton of a boat...a hole in the water you throw money into? But somehow worth it...sliding off the dock you lose all of the distractions, restrictions, and bustle of the land and somehow you feel free. Doesn't hurt that Lake Erie's so big you can't see the other side!
  14. #44
    Quote Originally Posted by HStream1 View Post
    I'm pretty sure 0A181487 is right, found that stamped on the little silver pin/button thing on the port side of the powerhead and when I put it into Mercury Parts Express it recognized it as 150 V6 Marathon/Magnum/XR-2 family from 1978-1985. Parts Express also showed 1150725 as and equivalent serial in parenthesis next to the one I gave u guys, maybe that's more useful? That one shows up as 150 XR-2 1978-1985 series motors.
  15. #45
    Quote Originally Posted by pyro View Post
    That's awesome! What kind of prop did u end up running for best results? Do you remember what size fuel tank was in her? The PO installed a 15 gallon steel bow tank, I'm wondering what the original setup was.
