Results 16 to 24 of 24
Thread: water in lower unit
05-05-2009, 03:10 PM #16Member
- Apr 2008
- BILOXI MS
- 40
I have been running Mercury premium gear oil it is thicker than high performance gear oil. I have had less trouble since using the thicker oil. It is alot harder to blow out the thicker oil under pressure.
05-05-2009, 04:54 PM #17
Hey guy's listen to this , I was on another Site corvaircenter.com trying sell a 66 Coravair that I picked up cheap and in reponse to my post a Merc Outboard Engineer responded to a pic I posted of my 32 Skater and said "please keep buying our engines " I responded by saying if Merc keeps on current course they will lose faith by those who love tehm and buy a white engine . I PM this Merc outboard Engineer the last post about bad coils and water in gearcase and he shuged it off like it was nothing . His screen name is aeroautometal
05-06-2009, 02:25 PM #18Member
- Apr 2008
- BILOXI MS
- 40
Ordered two new engines today they will be here next week and they aint black!!!!!! Its going to feel so good to fish my boat wash it and not have to pull the props and change the gear oil!!!!!!
05-06-2009, 03:06 PM #19
You could look at it as Exercise !!!
05-09-2009, 08:16 PM #20
Thicker oil = less MPH !!!! As previously mentioned I think the real problem is expansion . On my imco bravo shortie on my old race boat it was common for fluid level to rise and fall , rise when a whoppin was put to it and after cooling off it would settle . I guess I will have to market a kit like a Bravo !
Larry
05-10-2009, 02:53 PM #21Member
- Apr 2008
- BILOXI MS
- 40
That is the point I am trying to make brt24, you shouldnt have too Mercury should. Besides with all the technology and synthetic blends you no they make a non expanding gear lube. Mercury figured out how to coat there 300xs piston skirts with teflon for durability I think they can figure out a gear lube that wouldnt expand and fix there gear case problems, but the biggest question of all is why not???????????????
05-10-2009, 07:02 PM #22
Hey I'm right there with you !!!! Either they cant fix problem or too high on throne to admit there is a problem . I wonder if my Idea would work , same reservoir as bravo
05-10-2009, 08:45 PM #23Member
- Apr 2008
- BILOXI MS
- 40
Absolutly! Some already using it. Drill the shift shaft housing for a fitting run a hose the the engine pan hook up the puke tank. Lets it breath and you can keep a eye on the fluid level if it drops you know there is a problem. You can purchase it form Lakeland marine for the 300XS or easy enough make your own.
05-10-2009, 08:49 PM #24
Do you or anyone else ever used this set-up and what are results ?
