Results 1 to 10 of 10
Thread: 150 V- 150 inline parts swap.
03-17-2009, 06:11 PM #1
I have a 79 model 150 V6 20 in. Will the lower unit swap with a 75 model 150 20 in. Thanks for any help.
03-17-2009, 07:21 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 269
- 191
- 1975
old mercs
The Drive shaft has to be made longer..... by a small bit. Leave out the front stud. It is weeker so it will last as long as it does.
03-17-2009, 07:36 PM #3
03-18-2009, 07:20 AM #4
Can anybody add any iinfo on this swap I would like to do.
03-18-2009, 07:44 AM #55000 RPM
- Oct 2001
- Brunswick,Ga
- 362
The in-line won't last on the V. Also the shift shaft won't line up.
03-18-2009, 05:38 PM #6
Allrighty then, I guess I cant swap it. Thanks for your help.
03-18-2009, 07:30 PM #75000 RPM
- Oct 2001
- Brunswick,Ga
- 362
FYI the shafts won't interchange.
03-18-2009, 09:03 PM #8
03-19-2009, 08:47 AM #9
Later model inlines did have a swept back skeg and square plate. Look for later 115 with ADI ignition, not dist.
Never argue with an idiot. They drag you down to their level, then beat you with experience.
3 X APBA Formula V Nat'l Champion
APBA Formula V US-1
It took me 29 years to become an overnight success.
03-19-2009, 05:04 PM #10
thanks Jeff G.
Do you know if that lower is the same as the one on the older inlines.
