Results 1 to 15 of 23
Thread: Yami 300 HPDI questions....
01-25-2009, 03:09 PM #1
Picking up a 21' Checkmate BR w/300 Yami HPDI. Motor is an '05 model VZ300TLRD.
Yamaha VZ300TLRD
Year:2005
Horse Power:300.0
Cylinders:V6
Fuel System:HPDI/EFI
Tiller Handle:NO
Power Trim:YES
Full Throttle RPM Range:4500-5500
Left Hand:N/A
Gear Shift:F-N-R
Dry Weight:543
Exhaust:Thru Prop
Bore and Stroke:3.54 X 3.23
Jet Drive:NO
Stroke:2
Shaft Length:20
Starting System:
Remote Control:YES
Power Tilt:YES
Dual Propeller:N/A
Salt Water Use:YES
Alternator:50 AMP
Propeller Included:OPTIONAL
Gear Ratio:1.81
Question is what RPM/Props are you guys running? I've heard of people running them to 6K RPM even though Yami recommends 5500...
Any help is appreciated. Thanks!
01-25-2009, 09:32 PM #2
Gear Ratio:1.81........ !!!!!!!!!! 300hp
6000 rpm / 1.81 (yamaha)===== 3314 rpm in propeller
6000 rpm / 1.75 (mercury)===== 3428 rpm in propeller !!!more mph!!!
6000 rpn / 1.62 (mercury)===== 3.703 rpm in propeller !!! mooooore mph!!!!
Mercury is the best gear ratio!!!!
yamaha + gearcase mercury (1.62) = super yamaha !!!!
01-25-2009, 09:48 PM #3
01-26-2009, 08:17 AM #47000 RPM
- Sep 2002
- Lakeland,Fla
- 2,500
6000 is ok for that motor but not for long runs. 5800 would be ideal. They changed the rating on that engine a couple years ago to 6000rpm, they did not change the engine in any way though.
Fellow G-Man of the Sunshine Syndicate-Dixie Wrecked Chaptor..
We Put The F. U. in FUN
94 17MA Maverick 115 Yamaha
2006 Mustang GT, with a belt driven air cleaner
01-26-2009, 08:54 AM #5
your motor has a 1.75 ratio lower.run mine at 6000 all day.start off with 28 pitchhope that helps
01-26-2009, 02:06 PM #6
01-26-2009, 08:17 PM #7
is it a 20" or 25" shaft.. the saltwater series ran steeper gears for better torque transfer for heavier loads.. the 20"ers were all 1.75
01-26-2009, 08:41 PM #8
20" non-saltwater series
01-27-2009, 04:08 PM #9
1.75 ratio.. and revlimiter set to 6300... 6K all day long is safe..
01-31-2009, 03:08 AM #10
2003 To 2005
Thru 2005 Yamaha used 16 bit ecm. In 2006 they went to a 32 bit ecm. In 2007 they changed the ports in the block and called them series 2 . I have been told and I owed a 2005 and it does not make 300 hp.. I think that the 2007 and new Series 2 models do make 300hp but there is now way that the 2003-2005 made that much. By the way Hydro Tec can help you get over the 300hp mark. Good Luck
01-31-2009, 11:35 AM #11
01-31-2009, 12:53 PM #127000 RPM
- May 2001
- Charlotte, NC
- 2,272
- 85
- 566
- 802
285 hp.......sounds like the 300 ProMAx engines....
01-31-2009, 01:58 PM #13
After my warranty expires in 10/10 I will probably be giving Hydrotech a call. Until then, 285hp will be more than enough... thanks for all the replies. I pick it up Feb 18th! Can't wait!
02-03-2009, 02:05 AM #14Banned
- Dec 2007
- H.O.s Home Base!!!
- 464
A Yamaha tech told me that actually they were any where from 261-285, and that guys always felt the "hot" ones.....Like what was posted above 250xs mercs were keeping up with the hot ones and passin the slower ones....Im sure though the Yammie torque will be more important than the total top end HP of the merc on that hull, of course that 100HP Hydrotec Power Shot will really wake her up....Youd think Wayne and the boys would have some simply tuning and bolt ons to make her the 300-310 of the new Series 2 models, or darn close....Please post pics, that is one of my dream boats, once the 300 HO comes out then Ill be squirmin like a school girl....
02-03-2009, 10:58 AM #15
