Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 56
    Jul 2007
    Barboursville WV
    horn intake on pro max
    what would be the gain better or worse .
    to change the front half w horn off a 260 on to a 225 pro max.
    thanks
    Doug
    Aug 2005
    new iberia, la.
    you would lose a little on bottom end and gain very little (if any) on top. if you want to experiment with your promax, i would remove the water seperating filter on the motor and put it in the boat. i would also remove the reservoir/pump and run a 260 style fuel/pump setup with return line. this should allow better air flow.
    Dec 2001
    ST.CLOUD,FL
    why would he loose bottom end
    Is the PM intake quicker?thanks Dennis
    Jul 2005
    Beaumont, Texas
    Most people say the wet reed is a little snappier on the hit and through out the midrange. The Horn seems to produce a little more topend but not a whole lot. There was a couple of people making wet reed spacers for the horn motor. Came with plugs to put in the crankcase injector holes and moved the injectors to the front of the reeds..
    Rick
    2006 Gambler 2200DC/2006 250XS
    Aug 2006
    Bargoursville WV
    Thanks Guys
    Doug
    Shreveport, La.
    You should check into the Brucato slide front for your ProMax.
    DB
    Des Allemands
    rickster
    Can you tell me some of the names of the companies makeing the wet reed spacers?
    Jul 2005
    Beaumont, Texas
    Here is a starting place..
    GPI/Randy Pierson was selling them, machined by Chris Hildenbrand
    Rick
    Des Allemands
    Thanks Rickster.
    Jul 2007
    Barboursville WV
    Quote Originally Posted by Da Bull View Post
    DB
    Does the Brucato SVS Help the pro Max. ie is it worth the money.
    I do see several lookin for them.
    Thanks Doug
    MY set up.
    92 XRD 225 Nichols built 225 pro max 12" jack plate.. Brucato ACU Titus on 200case.26bullet cut proformer. Jay Smith heads.
    TN
    Rick[/QUOTE]
    How can wet reeds be snappier if the gas charge is further from the cylinders?
  12. #12
    Jul 2005
    Beaumont, Texas
    All I can figure being a layman is that the fuel being injected before the reed tends to atomize better passing through the reed cages as well as mixture distribution might be a little better .Maybe it gets a better ram effect being the aircharge is denser with fuel suspended.. The reeds probably seal better being wet as well as last longer as a bonus..
    I really do not have a scientific answer as to why it makes a difference but I have heard from several people that it does..
    Dunno,
    Rick
  13. #13
    Springfield,La.
    Datz a purdy good question........and I don't know if anybody haz a lagit reason for tha wet reed mota's bein quicker down low, BUT THEY ARE!!
  14. #14
    LAROSE LA
    I just wish someone could tell me if the horn and the svs are dry reed motors. how come everytime i ran mine and change the reeds, the reed and cages were full of oil. Also if the wet reeds are quicker how come 99% of all the progas, profuel and u-boats don't run them. Seems like it would be just the other way around. after all these guys are pro's and would do what ever it takes to win. later Larry D
  15. #15
    Springfield,La.
    Well, ya ole fart, I call it a wet reed mota kuz tha fuel mix iz flow'in THRU tha reeds when tha injectors are in tha front ov the reeds...Don't meen tha reeds stay dry...kuz they don't..az U already know!!!
    They are QUICKER down low and in midrange,(over the case injected mota)...Each to thier own, kuz I have seen MADD front motas kick azz in thoze classes(azz other types ov fronts with injectors in front ov the reeds)...I have personally tested diffrent types ov fronts on my pro120 motas and the wet reed motas wuz quicker, and depending on the typw ov front, wuz quicker thru the hole 1/4 mile...But, thats juss a 2liter...My ole 10pack wuz quicker than tha horn, but tha horn turn'd more rpm on top...Tha MADD front wuz quicker than both, and turn'd a few more rpm on top...
    We had this conversation one time at a race, and Big boy(Taylor, kan't remember hiz first name, Galen wuz drive'in hiz bote) tested hiz drag mota with a MADD front, first with injectors in the case, and then in the front(in front ov the reeds), he said there wuz a couple 10ths differnce, with the wet reeds bein quicker!!...I know U kan remember big boyz name, call him and let him tell ya juss how he did tha test, wuz very interest'in...
    I wunder if Dave Bush runs a wet reed mota???....
    Merry Christmas ole man!!!
