Results 1 to 7 of 7
    Port Richey Florida
    OMC Lower Unit Choices
    Doing alot of reading here and i am short a lower unit to get my boat back in the water ... Im running a 250hp V6 Evinrude and from what i understand i need a newer style lower unit with the tabbed bearing carrier..They have two styles one with a set bolt for the pinion bearing and one has a retaining clip for the pinion bearing... i would think the one with the set bolt would be better as it was for the commercial units but has been tough to find ... If i am running only 6000 rpms is this a big deal? i know since im running my motor high it will put added stress on the lower ..Thanks !!
    May 2001
    The Villages, Florida
    The pinion bearing retain by the bolt is much better
    Feb 2005
    if you surface the prop your putting a lot of stress on the LU. the long term solution id to convert to merc sportmaster with the fat shaft. its not cheap but after you loose a couple omc LUs, you'll wish you did.
    Port Richey Florida
    That sounds like a great idea for the long term ... for right now i think i will stay with a omc unit and see how long i can make it last ..not even sure how im going to like this motor .. lets see before i start throwing money at it ..
    still cant find a set bolt style lower ...how much difference will the clip style be ...
    Dec 2001
    Sunbury, Pa
    I ran the clip style for 13 years on my Sleekcraft with no problems. Mine liked the propshaft about an inch below the pad so maybe that helped it live.
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
    Port Richey Florida
    I think i will try a clip style... they are cheap enough... if it pops i will continue my search for a set bolt one....Thanks
    May 2005
    Greenville, NC
    There is no reason to convert to a Merc lower unless you are racing. Even then it's debatable. If you are only going to turn 6k you should never have a problem with an OMC lower as long as you pin the carrier.
    Ló fasz racing
    Joe Horvath
