Results 1 to 9 of 9
11-28-2008, 12:07 PM #1
Are Yami drag props worth fixing?
I've got a 26 Yamaha drag prop that I put about 10 hours on it. Last time out it developed a nice 2" long crack from the center of the blade to the trailing edge. After doing a little research, I realize that these Yamaha props are NOT an "everyday" prop. With all the flexible alloys in this prop, is this worth fixing? I know how pricey these are, but am I throwing good dollars on bad? For an "everyday" prop I'm looking hard at the Hoss Tritons and Hydromotive TX3s. Thanks for any advice.
11-28-2008, 12:50 PM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
SURE !!! They fix em daily... Send it to Tillman 1 251 645 9697 in Al.
JayJay @ JSRE
11-28-2008, 03:59 PM #3
i use one as a all around prop..... but use the taller pitches...... 30p i also use performance copies, and dont have any problems... i have several true yammi too.. how many rpm's do you spin it?????????????? if you going to spin it 9500 or more i dont know if i would use it....... may tear up your cavatational plate when it comes loose... 2" is a lot for those kinda rpm's....JMO
11-28-2008, 07:11 PM #4Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
I have a 24" thinn'd yamaha drqag that haz been welded 4 times...Never the same place...I have a guy locally to weld it, and balance it...Baggy haz worked it from the box untill now, and I kan promise if ya look'd at it, U kan never tell it haz been welded!!!....I wouldn't hesitate to run a professionally welded, and prepaired prop!!....If ya prop man is worth hiz grits, he willnot weld a prop if it iz questionable...JMO
11-28-2008, 07:31 PM #5
I just bought a cracked 22p yammi, It's going to Baggy's, when I get it back I H O P E & P R A Y that my 90 can turn it 9500
11-28-2008, 08:06 PM #6
11-29-2008, 03:53 PM #7
Yam drag
I've got a lt weight drag orginal, that everyone said was junk, after i hit bottom . Sent it to JC and then to 300 Below.Best prop I have.
M/E 1115 'Hot Pursut'
Mike Massmann
Stick it in,Get it wet,GO fast!!!
GONE BLACK !!
Member: Ray Neudecker's
OVER the HILL GANG OUTBOARD
RACING
11-30-2008, 09:28 PM #8
You are probably better off buying a Mercury Lightning ET to replace your Yamaha drag prop for everyday running,
but when it’s drag race time… the Yamaha goes on!
12-01-2008, 03:33 PM #9
a 2" crack on a trailing edge is a lot, for a everyday prop.......... i have welded to many different metals to remember them all.... that is the strongest part of the blade...
