Page 7 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 91 to 105 of 128
  1. #91
    You've got a LOT of grinding to do.
  2. #92
    Sep 2007
    Peterborough, Ontario, Canada
    Mehh, I can get in done in a week or soo if I work really hard, Im just too damn lazy
    "Brandon Field"
    Formerly Fieldzy
    Silly Rabbit, OMC's are for Kids
    1982 Hydrostream Vandal, Currently under Resto
  3. #93
    Sep 2007
    I got a question for you guys, How far should I grind into the glass where the core is?
    "Brandon Field"
    Formerly Fieldzy
  4. #94
    Nov 2007
    Rochester,NY
    Just untill all the old balsa and nasty chit is gone
  5. #95
    Sep 2007
    Quote Originally Posted by Streamin101 View Post
    lol sounds easy enough! Thanks!
    "Brandon Field"
    Formerly Fieldzy
  6. #96
    Sep 2007
    More pics!!! Pretty much cleaned out, Should I grind more out or is that good enough??
    "Brandon Field"
    Formerly Fieldzy
  7. #97
    Jul 2007
    Upper East Tennessee
    Looks good to me Feildzy, how's the 'itch'?
    You just want to have an even, rough ground surface to give the bonding material something to bite on without big surface irregularities that keep the balsa from contacting the skin.
    OK, I got down off the porch and ran with the big dogs....kinda sore now....think I'll just lay here in the flowerbed for a while...
    1976 Hydrodyne 18 I-O
    1969 Allison 15R, 1973 Merc 1500 (project)
    1995 Harris toon
  8. #98
    Dec 2003
    rockford ill.
    better b careful
    U grind much more n re-move core,that s.o.b.'s gonna wanna fall apart on the trailer.
  9. #99
    Quebec. Canada
    It's a big job but after this work done this boat gone have a great value... JP Love
    Go boating,be happy!! And wear safety vest please!! And lesson good music...https://www.youtube.com/watch?v=2c5oHITTI8c
  10. #100
    Sep 2007
    Quote Originally Posted by oldskier View Post
    Cool! Just wanted to make sure that I didn't grind too much or not enough. The itch an't bad actually, Just keep skin covered and im good And the weird thing is I enjoy doing this sorta work
    better b careful , U grind much more n re-move core,that s.o.b.'s gonna wanna fall apart on the trailer.
    I hear ya Big B! This thing is flimsy as hell, Hopefully I have it supported good enough!
    Great value? The only reason im doing this is because I want a fast cool boat!
    "Brandon Field"
    Formerly Fieldzy
  11. #101
    Sep 2007
    Also, I had to cut out the rear flotation foam, I was going to leave it in but was amazed that after cutting into a couple inches of dry foam that half of it was compelety Saturated, Full or water. Soo its all coming out for both sides. I assume that it was wet because of a leak in the repaired wing.
    "Brandon Field"
    Formerly Fieldzy
  12. #102
    Sep 2007
    Here's some pics from the beginning till now
    All de rigged and ready to start cutting and grinding! I like it better without the windshield, Don't you think so too?
    "Brandon Field"
    Formerly Fieldzy
  13. #103
    Sep 2007
    Got a center bunk for the pad to sit on
    Cut splashwell and inner transom skin, A little bit of rot around the old inline bolt holes, So Its all coming out!
    Cut into the core and guess what! BLACK MUSH! Bright side is it comes out pretty easy!
    Stringers wet and rotten too!
    "Brandon Field"
    Formerly Fieldzy
  14. #104
    Sep 2007
    A lil bit of repair on both wings and bow, I assume it was in some sort of accident. Bottom was painted also...
    "Brandon Field"
    Formerly Fieldzy
  15. #105
    Sep 2007
    Core and stringers out and inside cleaned out! Also cut out the flotation foam I thought was dry was Soaked and staturated
    (If you can see there is a hole where I accidently poked my chisil threw when getting the core out, WHOOPS)
    Transom out and cleaned
    "Brandon Field"
    Formerly Fieldzy
