Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 15 of 128
    Sep 2007
    Peterborough, Ontario, Canada
    Hydrostream Vandal Restoration (Maple Leaf edition)
    Since I was a little kid I have always been fascinated with Hydrostream's. Being that my nextdoor neighbour cousin's had 2 Hydrostream V King's I fell in love with there sleek design and there cool colour scheme's. Hearing them rumble down the lake, I would always run to the window to watch them race by. Since then have always been looking for a small hydrostream. Mostly looking at Voodoo's and the odd Viper or two. But they all had the same "look" to them, Not that I don't like Voodoo's or Viper's but I wanted somthing Different but still a along the line of a hydrostream. So one day my dad said a buddy of his had a Hydrostream. Went to take a look and the rest is history. So now I have a 1982 Hydrostream Vandal, Black with Red Metal Flake. Having read just about everything on Hydrostream and looking at the shape of this boat I knew that it would need a complete Restoration. Having no experience in this im going to need all the help I can get. But I don't think it will be that big of a problem thanks to S&F and all there helpfull members. So I will try and document step by step. Any comments and tips are apprecated. Thank you
    "Brandon Field"
    Formerly Fieldzy
    Silly Rabbit, OMC's are for Kids
    1982 Hydrostream Vandal, Currently under Resto
    Jan 2008
    forked river ,NJ
    congratulation's on ur new boat and u will have fun with it when ur done its going to be a hard process restro it but u got us to help u out lol .im finally startin to sand mine and prep it for paint hour and to many hours later also ur going to need money and at least a good 800 to even get started any questions with wat to do just send me a pm and ill do my best to help good luck post some pic's to
    14' lowe (20-24 mph)
    13' Mini Hawk (unknow yet) under restro
    http://forums.screamandfly.com/forum...d.php?t=164779
    If your not living life to the extreme your not living life to the fullest
    Jan 2008
    forked river ,NJ
    Fieldzy wow thats u y u change ur name u got me all confused lol u know wat ur doing lol
    Sep 2007
    Quote Originally Posted by fastlane35 View Post
    Yes man it is me I deciede a more "Canadian" name was in order. Sorry to confuse ya!
    "Brandon Field"
    Formerly Fieldzy
    Sep 2002
    Parry Sound, On
    First tip....buy a good face mask. Breathing FG dust sucks!!
    Tip two...do as much work as you can but get Spaeth to put the core in. It will save you money and time in the long run.
    It'll be a great project and something you'll always be proud of.
    '08 SRV
    Yamaha 3.1 Phase III
    Jan 2008
    forked river ,NJ
    lol its kool so did u start restro yet
    Sep 2007
    Quote Originally Posted by DoktorC View Post
    Well do. I know John Spaeth does great work, But I really want to learn this stuff. Thats the whole reason I got this. Its a project and I want to restore it myself and look back at all the work I've done.
    "Brandon Field"
    Formerly Fieldzy
    upstate N.Y.
    you'll do well,Brandon,but first DO YOUR HOMEWORK!!!
    why ask me ?
    Jan 2008
    forked river ,NJ
    Sep 2007
    Thats a Ventura Fastlane. I will get some pics of shortly
    Quote Originally Posted by stokernick View Post
    Homework is always first!!!
    "Brandon Field"
    Formerly Fieldzy
    Sep 2002
    Parry Sound, On
    You'll learn more then you can imagine from John and be gaurenteed that it's right. He's also the best place around for material. I do all my own work for the same reason...but...there are certain things that are best to have expert guidance in. You'll get to help so you'll learn plus you've got an expert to make sure it's done right. We're lucky to have a guy so close..
    '08 SRV
  12. #12
    Jul 2002
    South Florida
    You don't need a lot of money to get started, but you will need it eventually. At least the Vandal is small so it doesn't use a lot of materials.
    Start with:
    -Organized place to work. Ideally inside, but you'll want to move it outside for grinding.
    -Build a jig, either on the ground as I did or on the trailer, to support the boat.
    -Strip all the hardware off of it, bag and keep what you can.
    -Tools: chisel, hammer, air chisel, hacksaw, skill saw, sawzall, and an angle grinder (I used 60grit disks). The chisel, grinder, and disks I got at Harbor Freight for under $30. Good breather mask and some tyvek suits.
    I chose to split the deck off the hull. It makes working on the hull much easier. But it can be done by just removing the motorwell. Don't cut the transom skin unless it has some obvious damage or a previous repair.
    While you're in demo mode read all the threads on here and figure out how you want to rebuild it. On a budget, I'd use BS1088 plywood, balsa, a locally-available shop brand epoxy resin, and biax cloth.
    78 Hydrostream Vandal - under restoration here: VANDAL RESTORATION THREAD
    86 21' Eliminator Daytona
    17' Badetta sandbar skiff
  13. #13
    Sep 2007
    Quote Originally Posted by Matt Gent View Post
    Start with:
    Thank you! I was waiting for somone to post somthing like this I apprectate your advice. It will help alot
    "Brandon Field"
    Formerly Fieldzy
  14. #14
    Sep 2007
    Here's some pics
ID:	178793   Click image for larger version.
ID:	178794   Click image for larger version.
    "Brandon Field"
    Formerly Fieldzy
  15. #15
    Sep 2007
    Some more
ID:	178798   Click image for larger version.
ID:	178799   Click image for larger version.
    "Brandon Field"
    Formerly Fieldzy
