Results 1 to 9 of 9
Thread: Yamaha Prop On Mercury
09-08-2008, 04:04 PM #15000 RPM
- Jan 2008
- CYPRUS
- 237
I have a yamaha hi performance propeller (small hub)
and i was wondering if ican fix it on an optimax 200.
is this posible?
09-09-2008, 05:51 PM #25000 RPM
- Jan 2008
- CYPRUS
- 237
no one?
09-09-2008, 09:04 PM #3Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
I think it should fit but count the splines, they should have 15...
Kevin Kiser
09-10-2008, 06:25 AM #45000 RPM
- Jan 2008
- CYPRUS
- 237
Both the engine and the propeller have 15 splines.
What about the thrust whasher?
09-10-2008, 06:47 AM #5
Yamaha prop on Merc
The splines are the same.
There is a one degree difference in angle between the shoulder on the propshaft on Merc. vs. Yamaha, so a Yamaha thrust washer does not quite fit a Merc.
There are prop shops that offer special washers.
However, in practice, the brass is soft and lots of people use Yamaha thrust washers on Mercs, so I would not worry.Markus' Performance Boating Links:
09-10-2008, 11:37 AM #6
Yamaha Thrust washer
I have run the Yamaha thrust washers for years on Mercs. The only thing is that you need to cut of the little protruding portion of the thrust washer that would push against the prop shaft seal on the mercurys prop shaft. That small lip must be removed or it will destroy the prop shaft seal. You can just cut it off with a hack saw and then file it smooth.
Carter Powell
09-10-2008, 04:04 PM #75000 RPM
- Jan 2008
- CYPRUS
- 237
Thank you
09-10-2008, 04:18 PM #86000 RPM
- Oct 2006
- Florida most of the time
- 1,037
How about Mercury props v6 on a v6 4 stroke suzuki??
09-11-2008, 09:33 AM #9
The 2-stroke Suzuki V6 engines had OMC style prop shafts that don't have splines all the way. I don't know about the 4-strokes.
