Results 1 to 6 of 6
    Nov 2003
    Saint Inigoes, Maryland
    1986 Mercury 7-pin iginition switch wiring help
    I have a 1986 2.4 Mercury Bridgeport outboard. It has a 7-pin cannon-type harness on the engine. I purchased a 7-pin wiring harness to run to the front of the boat....but it has no ignition switch. Can someone tell me or e-mail me at (joeblr_999@hotmail.com) how to connect an ignition switch to this harness? Can I use a universal marine ignition switch or, will only a Mercury switch work? Does anyone have the wiring diagram for connecting the switch to my 7 pin harness? Any help would be greatly appreciated...Thanks.....15 Mustang
    Shreveport, La.
    Yes, A universal push to choke switch will work and it comes with instructions on where to put what wire. All you need to know is what wire does what and i`m gonna tell you that.
    Red-battery positive
    Black-battery negitive
    Purple-12V pos with switch on
    grey-tach sendor
    Yellow/Red-start
    Black/Yellow-kill wire
    Tan/Blue-water temp sendor
    Dark Brown/White-trim guage sendor
    If i may make a suggestion, Use heatshrink and eyelets without protective insulation and solder the wire to the eyelet after you cremp it. Then slide the heatshrink over the eyelet and shrink it. This makes for a perfect connection and won`t give you trouble down the road.
    Let me know if i`ve left anything out.
    DB
    Jan 2005
    South Florida
    I thought the yellow w/red was the kill?
    Nov 2003
    Da Bull ....thanks for your quick reply....15 Mustang
    Lake Congamond
    the yellow red is the start circuit but sometimes it will go through a neutral safety switch on the shift box. I believe this is what is confusing.
    Nov 2003
    Replies on the yellow/red wire
    Thanks everyone....for the additional information on the yellow/red wire for my Mercury wiring harness.
