Page 52 of 54 FirstFirst ... 2 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 LastLast
Results 766 to 780 of 797
  1. #766
    Nov 2005
    Plaisance, Québec, Canada
    just a hint .... what would be a start setback for a Big 3.0L V6 Merc for My HST ??
    I've tried 4'' up to 14'' and, to my feelings the 14'' was a whole lot more fun.
    Glastron GT 150 W OMC 140
    Glastron GT150 w OMC 235
    Hydrostream Vision with 2.0l 135
    Hydrostream HST w 3.0L 225
    I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
  2. #767
    Belgium
    Hi Tony,
    Can you show some pictures of the strakes? I heard about this mod but never seen it? Aren't there also extra sprayrails in the tunnels? What kind of performance with the 200? Thx
    Quote Originally Posted by waterpilot View Post
    I also am new to HST(In the last year) Somehow ended up with 2 HST's. The one I'm currently running is a Black Bruiser jel sceme full interior with a
    3ltr 200 Evinrude/Johnson 20" Vindicator mid 14in setback. It's a blast to fly. I love it. It has the aluminum plates at the extentions as well. It also has extra lifting strakes on the outside sponsons my other one doesn't have. No aluminum plates on the extentions on the white one either. The center Stepped Pod/pad is the same on both.
    The other(white with red,grey,black, multi color sceme) I'm restoring so its lighter, stronger and hot rodding a Rude 3.4ltr w/16in mid for it. Still at least a month out on this one before I get her wet again.
    Tony
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  3. #768
    Belgium
    Where are all the hst owners?
    I ran mine a couple of times. Boat runs good. Still have the propshaft deep because I have a stock 200 lower. I'm about 3" below.
    Ran an 28 chopper and 29 srx. Both blow out at about 85mph. This is with a stock 2.5 200.
    Very excited how it should run with a LWP or a cle. Low 90's was my goal (150km/h). W'll see if that will work or not...
    I will install a trim meter gauge and prob also side steering this winter.
    I added some videos.
    Fletcher 17F6
    Hydrostream HST 20F
  4. #769
    Dec 2011
    Ottawa
    I own an alpha echo 21,got the guts out of it now,just gotta remove the rubrail,sand the top side and grind the innards to get a tooth for new glass.
  5. #770
    Dec 2011
    Ottawa
    I too would like to know about any 3 liter merc setups. I have a good 200efi and a new 250 pro xs, got a 225 promax that would need a rebuild too,i have all the right 2.5 parts,4" setback bracket,12" bobs hyd. Plate,offshore mid and titus coned cle.
  6. #771
    Belgium
    There are 2 ae21 with 300 pro max. Another with 250ho. Weight is no problem. There was also An hst with 300x that ran real hard.
    Weight Will not Be a problem. Good setup is key To succes.
    Fletcher 17F6
    Hydrostream HST 20F
  7. #772
    Dec 2011
    Ottawa
    what kind of setback for the 3l's ?
  8. #773
    Belgium
    I think about 8 maybe. But hard to say. Depends on the weight of the boat and weight distribution. At100plus on here had an hst with 3litre rude 225 indicator with 3 cmc jackplates bolted to each other.
    Dabull had an hst with 3litre merc. Ran great from what he told me. Might contact him or maybe he will jump in.
    Fletcher 17F6
    Hydrostream HST 20F
  9. #774
    Dec 2011
    Ottawa
    I have a 12" bobs action, dont really wanna spend $1200 for an 8 lol,my boat will be all freshly restored with no foam, but will be heavy with fishin' tackle at times, i love to bass fish,and i have a paramount 21 to fish,but sometimes you just gotta' spank some other bass boats, kinda like an ally with a livewell and a troller.
  10. #775
    Belgium
    Quote Originally Posted by Varmint View Post
    Maybe Bob's might sell just the sides of the jack seperately. Worth a try if 12" might be too much. I think 12" is quite some...
    I have a 2.5 200 and 10" setback. I feel it might benefit with some more setback but think will leave as it is.
    Fletcher 17F6
    Hydrostream HST 20F
  11. #776
    Dec 2011
    Ottawa
    I have a 200 efi with 140 psi in my shop with 140 hours on it, it's an 04 with motorola electrics,offshore mid and titus coned CLE i figured it was too small.it's a great bass boat motor.
  12. #777
    Too small for what? It ought to go 90+ with that motor; even bolted directly to the transom.
  13. #778
    Dec 2011
    Ottawa
    It only has a 6050 rpm limiter
  14. #779
    Nov 2005
    ok, Here are some numbers.
    I have a 3.0L merc, carbed with an Hoss prop 15''X 30'' and a PARALIFT Jackplate from mercury with 8'' setback and SeaStar Hydraulic steering.
    My last run this fall was 155km/h all alone with half full fuel tank located in the back (25 gals max).
    Here is the vidéo of multiple runs at 154 to 155km/h.
    https://www.youtube.com/watch?v=N2DvrBWrtFU
  15. #780
    Belgium
    Varmint, what is your goal? How fast do you want to go? Go out alone most of the time or with passengers?
    Fletcher 17F6
    Hydrostream HST 20F
