Results 1 to 15 of 20
    Northern/Southern ky
    mercruiser trim pump oil ?
    do i use merc trim oil for the mercruiser style pump?????
    i had the oildyne before... is it nessesary pump all the old oil out of the ram??
    thanks,
    roy
    93 xr 2001 drag with a 15" drag
    92 xb 2002 comp with a 15" drag
    R.I.P. Phil "rpm racing" Watch over the rest of us my friend.
    May 2005
    Greenville, NC
    I've been using tranny fluid in both of mine. It speeds them up a bit.
    Ló fasz racing
    Joe Horvath
    Springfield,La.
    I use trannay fluid in 2 and a lighter hyd oil in one....the hydrolik oil one iz a tad quicker on 24 volts, but about the same on 12v.....JMO
    should i bleed the entire system
    roy
    May 2005
    Greenville, NC
    Just get most of it out. It'll be ok.
    Ló fasz racing
    Joe Horvath
    cool thanks,
    roy
    May 2008
    Atmore, Alabama
    Transmission fluid, power steering fluid...I even know some folks who use 30W motor oil (which seems a little heavy to me, but it works).
    Just stay away from anything that has detergents in it...it tends to make a lot of air bubbles.
    I just replaced my old Oildyne trim pump with a Mercruiser model. Got all of the old fluid out of the ram cylinder that I could, without going through any extra trouble, then filled the new reservoir with power steering fluid, worked out all the air, refilled the reservoir, and went boating. Works flawlessly.
    Canada
    Oil
    Quote Originally Posted by jphii View Post
    I have always used Amsoil Tranny fluid aswell. Seems to be quicker .......
    As flo - Joe said
    Gothenburg, Sweden
    Quote Originally Posted by h2oskiier30 View Post
    Yes, that's the way it is.
    St. Cloud, FL
    I've used Marvel mystery oil in the past, but recently have been using tranny fluid. If that mercruiser pump is not new, pull the resevoir off of it, and make sure the "socks" on the end of the pickups are clean before putting new oil in it. They can clog up and cause you a headache if the get some crap in em'.
    2006 Spectre 24' SCS
    2020 Mercury 300 ProXS
    2001 Allison XB2003
    2006 Mercury 250XS
    1988 22' Velocity (sold)
    1995 Allison Grand Sport (sold)
    1998 Mercury Stock 2.5-260 SS
    1990 Velocity 30' - 502's (sold)
    Go Daddy Go! Racing
    thanks guys
    roy
  12. #12
    Jan 2005
    Kentucky
    Roy, be careful with that new mercruiser pump...Up is fast, but down is even faster!!! It can get harry at first until you get use to it...
  13. #13
    Ft. Lauderdale, Fl
    The service manuals call for either the Merc trim fluid or 20W oil.
  14. #14
    Springfield,La.
    It ain't dat........
    Mercury juss ain't figger'd out how to make it allisoon frenly yet!!!!.....Give Darris time, I bet he will have a pump specially fer one ov them hook'r botes.....
    Maybe U could hook tha down side on 2 "D' SIZE BATTERIES
    Sorry....tha devil made me do it
  15. #15
    Minnesota
    I just installed a fast pump in my ally and have had a couple of suprises coming down from speed. She's tried to come around to the right a few times now. You have to be real careful with the down trim.
    Btw, chalk one more up for Marvel Mystery Oil.....
