Page 9 of 36 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 ... LastLast
Results 121 to 135 of 529
  1. #121
    Jul 2004
    Picture test
    I think I figured out the picturing posting. Like the above post states I've had this boat for about 5 years but for some reason I never took a picture of it. Current set-up is...1998 20.8' Lavey Craft Sebring with a 99 300 Pro Max spinning a 23" high five. Hydraulic jack with 14" total set back. With this prop it doesn't scream or fly but will run all day with a boat load of gear and people. I have seen 78 mph on gps with a prop change. I think that was with a 28" trophy +.
    Attached Thumbnails Attached Thumbnails SANY1073.jpg   SANY1076.jpg   SANY1080.jpg
  2. #122
    Nov 2003
    Simi Valley, SoCal
    Nice ride Billy. Need pics on the water...boats in a driveway never look quite as good as they could. Also I would like to see the interior. I want to change my layout a bit.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
  3. #123
    Nov 2003
    Simi Valley, SoCal
    Quote Originally Posted by LaveyT View Post
    2000 225 H.O.
    Best GPS with the H.O. 84.3
    Best GPS with a modified 260 Merc 94.7
    Runs consistant 80-83 mph
    Hi T,
    What props have you tried and what were the RPMs on the 260?
    Bob
  4. #124
    Mar 2003
    spring lake,mi & freetown, in
    Quote Originally Posted by billyindex View Post
    That is a good looking boat! Very balanced looking with the big motor.
  5. #125
    Cincinnati
    Rpm
    Quote Originally Posted by luv2gofast View Post
    Hi T,
    Bob
    I ran a 27 " Yama Copy " quite a bit. It would run 91.7 with that prop. Its been about 6 or 7 years ago so my memory may fail me as far as RPM goes
    It was a modified 260 with modified porting , bored horn , 155 psi compression and a 1" spacer. As I recall both props I ran turned under 8000 RPM. 7500-7800 was normal.
    The Yamacopy didnt have enough bow lift for the best top end.
    The only other prop I ran was a big ear chopper re-worked by Spinelli for a bow heavy Shadow bass boat. That is the one I got 94.7 mph with. A world of difference with bow lift. The Yamacopy had a ton of slip on accelleration and it worked well for powering the Lavey up to 90 MPH. I never reilized that the 260 had a limited bottom end untill I put the Chopper on it. I wasnt used to the Merc straining at all.
    All of that being said "full lift" needs to be obtained at a lower speed to decrease E.T.
    A blueprinted Bravo 1 is supposed to be the best prop for top end and I suspect acceleration. I say acelleration because when I ran a 30 Bravo 1 (way to much pitch) the bow didnt drop and the hull didnt drag. I trimmed it up hit the gas and it stayed high. It basicly held the bow up instead of waiting for the hull to get enough air under it.
    Good luck and let us know what works.
    Thanks,
    L.T.
  6. #126
    Sep 2007
    Epsom N.H
    Thanks,
    Good info. I am going to try a Mazco 26" RE3 and also a Big Ear 28 Chopper this weekend and also have a Turbo TXP4 OT 27" to try also. What set back are you guys running and how high are you running the motor???
    Thanks Steve
    My Personal Boats
    1996 STV River Rocket with 260 Mariner SOLD
    1942 Century Sea Maid 17' Split Cockpit Barrel Stern 175 HP Flat Head 6 cyl.
    2004 Moomba Mobius LSV 23' V Drive 345 HP Wakeboard Boat
  7. #127
    Dec 2006
    Plano, Texas
    Man thats alot of work. You have the same Trailer as I do. Thats what needs the work on mine. Lots of surface rust. My transom still looks great. No plate needed yet !
    Was that Ron Hills old Boat ?
    Yep...Ron's old boat.
    Might be selling soon or wait until the Spring after I put new interior in it.
    see mine here
    Divorce sell.
    Stock 200 runs MUCH better than the Frankenstein 2.5 it came with when I bought it.
    Best regards,
    David
    1989 Lavey 20.8 Sebring Mod-VP
    formerly DEAD 1995 2.5 Mercury with carbs.
    Now, 2.4 200 as it came from Mercury...Stock!
    22" small hub HighFive
    5900 rpm fully loaded down with friends and cooler
    6200-6300 rpm with me alone.
    We ski, tube and pleasure boat
  8. #128
    Sep 2007
    Epsom N.H
    Props
    I ran the Lavey this weekend and tried a few props. The lake was like glass and not what these boats like. I ran a 26 Mazco but had no bow lift. Just had the hop at 65 -70 and didnt want to come out of it. I put on a 28 Chopper and did the same. I put on a Turbo TXP OT4 27" and the boat finally had some bow lift. I ran 86.5 on GPS MPH at 6,600 RPM. I think if I had a 25" and get the RPMS in the 8,000 range it should run mid 90s plus. I am going to try and find a Bravo 1 25" to try and also a Turbo TPX OT 4 25". Anyone other help would be great.
  9. #129
    Mar 2003
    Quote Originally Posted by moomba View Post
    Those #'s show a 4% slip. As good as could ever hope for if the prop is really a 27 and the tach is right.
    27 x 6600 x .535 x .000946 = 90.18 mph, x .96 for slip = 86.57 mph.
  10. #130
    Sep 2007
    Epsom N.H
    Quote Originally Posted by sms View Post
    The prop doesn't look to have been worked. It has had vent holes drilled. Its a little slugish out of the hole with this prop. I am going to call Turbo Props and talk with them. As far as I know the tac is correct.
  11. #131
    Nov 2003
    Simi Valley, SoCal
    Do you have a 1.87 lower? If it's 1.75 the slip would be 10% (86.8) which is closer to what I would expect. If you are realy getting 4% that's fantastic.
  12. #132
    Sep 2007
    Epsom N.H
    I have a 1.87 Lower. I talked with Turbo and they said this prop is more like a 28" at the trailing edges. They were not much help but they have someone calling me tomorrow. I am going to talk with Performance propeller in Tenn tomorrow and see what they come up with.
  13. #133
    Sep 2007
    Epsom N.H
    Quote Originally Posted by HavasuDreamin' View Post
    Same thing happened to me. One piece shaft cost me $522 in 1997 but it was the best money I ever spent.
    Moomba, you need a built case. I would highly recommend a case with a one piece shaft and a large bearing carrier. Best of luck.
    I have a CLE with a Bobs Cone that has a cracked skeg on a lower. It has has good internals. I am going to put the internals in another case. Here is the Question.
    Do I put them in a stock CLE case or a Bobs Coned 200 Case??? I have one of each that I could use.
    My Personal Boats
  14. #134
    Mar 2003
    This turned out to be the last run of the year, unless it's 70 some day after hunting season.
    In eastern Ky recently:
  15. #135
    Cincinnati
    Where
    Is that Laurel Lake ?
    L.T.
