Results 1 to 4 of 4
06-13-2008, 01:26 AM #15000 RPM
- Sep 2005
- Bendigo,Australia.
- 393
1:75 Sport Master Gears in a Torque Master.
Can it be done??
Based on part numbers the answer is no.But the drawings and design look the same.
So is it possible the put the internals of a Torque Master in a Torque MasterTwig.
06-13-2008, 02:36 AM #2
I am pretty sure the 3 litre sporty and torquemaster are the same twig, only thing the front bearing comes in three differant sizes. Found out the hard way, 3 trips to Isherwoods from heidelberg in the one day. We also had to take a thou of the inside of the reverse gear. Your 2.5 carrier spanner won't fit over the propshaft of a fat shaft box.
97STV EURO & MERC 2.5 260
06-13-2008, 02:51 AM #35000 RPM
- Sep 2005
- 393
So
Its nothin that Kenny Gotts couldn't fix??
Twig.
06-13-2008, 08:43 AM #4
you could put 1.62's in there if you want. as stated above, you just need the correct carrier and components. The case will accept it though.
