Results 16 to 30 of 45
    Jul 2002
    S. Florida
    Just a shot in the dark but if ya have the 1.62 gears then the props need vent holes to get her turning.. Have ya tried an overhub prop to see if the holeshot changes??
    07 STROKER 300X
  2. #17
    Daytona Fl.
    7 Post(s)
    Quote Originally Posted by Largemouthlou View Post
    I also thought about that, but he's losing it on the top end too.
    Boat Delivery available
    Things owned. NOTHING!!
  3. #18
    Feb 2008
    Wharton, TX
    Dropped her off with Merctech5591 today, thanks for the help guys.....
  4. #19
    Feb 2008
    Wharton, TX
    Talked to Merctech5991 and he said the gaps on the plugs were all over the place and one plug had an electrode that was twisted. No one that I know of has been in the motor since it was shipped from the factory. Weird.....Hopefully I'll be picking her up tomorrow.....
  5. #20
    Aug 2005
    Pembroke Pines , Fl
    took the boat out today for a ride.. lake was really nasty so only got 71 mph.. @5200 with a 27 trophy there's plenty more to get but had no water to run in.. . i'll be taking it to the river tomm and ive got 5 prop's to try.. i'll keep you posted..
  6. #21
    Aug 2005
    Pembroke Pines , Fl
    lake test
    well took the boat out this morning was at the lake by 7:00, it was awesome no boat's and plenty of clean water.. i tried a 30p lab bravo, 27 std bravo, 27 trophy, 25 tempest, and a 5 blade hill 26p. all prop's ran in the 70's.. best prop's for the boat was the 25p tempest, better hole shot and much more acceleration. and the 26p hill..both of these prop's ran 75-76mph. a 28 5 blade may yield a bit more speed as it would turn it up to 6200 rpm.
    ryan call me up, the boat will be ready for p\u tomm.. thanks rick
  7. #22
    upstate N.Y.
    so what was the problem?poor spark plug gaps??
    why ask me ?
  8. #23
    Feb 2008
    Wharton, TX
    Rick, PM me your phone number, my Blackberry died and I lost all of my numbers....
  9. #24
    Aug 2005
    Pembroke Pines , Fl
    Quote Originally Posted by stokernick View Post
    spark plug gap's were from .024 to .030. spec is .032. also one electrode was bent and one would not fire under load.. so two bad plugs was the problem. i haven't had many problem's with the 300xs and i have rigged and sold a ton..
  10. #25
    Gothenburg, Sweden
    Quote Originally Posted by merctech5591 View Post
    Well, given the weight of today's DFI and 4-stroke engines, a ton of engines is not as many as it used to be...
  11. #26
    Aug 2005
    Pembroke Pines , Fl
    Quote Originally Posted by markus View Post
    well, Given The Weight Of Today's Dfi And 4-stroke Engines, A Ton Of Engines Is Not As Many As It Used To Be...
    I Should Refrase And Say A Few Ton.. :d:d
  12. #27
    Mar 2005
    Nashville / Tullahoma, TN
    ugh. well now I can add to this post.
    Our 300XS has 104 hours on it. A couple weekends ago, I was out with some friends when the motor started not being able to turn the RPMs like normal (only around 5000 to 5200) and after more cruising, it got worse, and worse. No horns or error messages on the Smartcraft gauges. So then, it gets so bad, that the boat cannot even plane out.
    After pulling all the plugs, the #6 plug was fouled pitch matte black.
    We replaced the plug, and took it back out. It seemed to be back to normal (thank god), but that only lasted about 5 minutes. I was able to get my 6200 RPMs out of it for a brief 10 seconds or so... but then it just keeps missing (i guess) and is only good for about 5000. And the hole shot is TERRIBLE. I tried to have my dad tow me for a barefoot pull. He was WOT trying to get me surfaced... and then, once I was on my butt on the surface of the water (being very very little drag at this point) the engine KICKED and rreally messed me up.
    So anyway, we pulled the #6 plug and there is carbon on it, too. Anyway... off to the shop... I'll keep yall posted.
    '95 Diamond-Back
    '03 Triad V21
  13. #28
    Aug 2005
    Pembroke Pines , Fl
    sounds like a bad fuel injector dumping too much fuel in that one cyl.. or a coil failing.. i guess i've been lucky with mine no problems yet..
  14. #29
    Feb 2008
    Wharton, TX
    I just wanted to give a big THANK YOU to Merctech5991. Rick has bent over backwards to help me out in one of the busiest times of the year for boat mechanics. He was able to quickly fix my problem and has been a pleasure to do business with. Anyone in the Houston area who needs a good Merc mechanic should look him up at Capt. Kirk's Marine in Spring. Top notch guy and a top notch outfit. THANKS AGAIN RICK!
  15. #30
    50 miles south of Augusta Ga.
    Got a close friend with three 300xs and has had a bunch of coils go out lately. May not be ur problem but there are some with bad coils out there. Just something to keep in mind
