Results 1 to 8 of 8
    Aug 2003
    Mathiston, Ms
    changin my 245 carb mota to a horn mota????
    im thinkin of convertin to a horn mota on my 245. i need a detailed list of every thing ill need. can yall help me with this? thanks in advance.
    Matt
    aka boilerdawg
    Boatless for the first time in 20 years.
    You will need :
    1. EFI front half
    2. 6 injectors
    3. ECU
    4. Linkage rod assy.
    5. Fuel rail
    6. Regulator
    7. Orficed Tee below return line
    8. ECU bracket ( mounted on on horn )
    9. 6 injector bolt spacers ( 1" black alum. )
    10. 6 1/4" 28 lock nuts and washers
    11. ECU harness holder ( attaches to ECU bracket)
    12. ECU harness
    13. Plenium gasket
    14. 6 plugs to plug off fuel bleed system on 245 carbed engine
    15. 6 rubber injector holders "O" rings
    16. 3 injector nylon holders ( attaches injectors to block )
    Let me know if you decide to do this as I have 75 % of this stuff used and will make you a deal on them..(From customers parted out engine..)
    Jay 1 281 576 5088 cst
    Jay @ JSRE
    Aug 2003
    Mathiston, Ms
    thanks jay for that info. im lookin at a blown 260 now but its torn down, i want to make sure i get all i need for the change over. pm me with a price on what ya got i may be interested.
    matt
    Matt
    aka boilerdawg
    Northern/Southern ky
    a different fuel pump too..
    93 xr 2001 drag with a 15" drag
    92 xb 2002 comp with a 15" drag
    R.I.P. Phil "rpm racing" Watch over the rest of us my friend.
    Georgia
    7 Thread(s)
    I've done it with one of mine and think it's a REAL GOOD upgrade. You'll need to block the bleed hose fittings on the side of the block also.
    Aug 2003
    Mathiston, Ms
    what about electronics?? tpi's and such?
    Matt
    aka boilerdawg
    All the "goodies" are internal on the new digital boxes...
    Jay
    Jay @ JSRE
    Sep 2006
    Texarkana, Arkansas
    I recently switched my carb motor over to EFI. I choose the 225 setup because it was cheaper and I am very impressed. I'm sure the horn style would have given me a little bit more though. Good luck on it.
