Results 1 to 15 of 30
    Jan 2005
    levitown
    drag crank,has a coller or spacer between bearing and crank is this normal?????
    i have a 2.5 drag crank large bearing upper and there is a coller or spacer around the crank , it goes between the large bearing and the crank!!!!!!
    is there a part number for this coller or spacer i would like to get a new one or is there a bearing that fits without the spacer ?????
    ILLINOIS
    Cool Yes
    Its normal. The early double roller 5208 bearing ( big upper bearing) cranks with the tungstan heavy metal weights welded into the top (1996 and newer), had a sleeve. Basically Merc was using up the cranks that had already been ground to size for the older bearing ( the roller type). They then cut the upper throw, added weights and pressed the sleeve and bearing on. Later when those were gone, they started grinding the upper OD of the upper journal to match the 5208 bearing. Absolutely normal, and no you can't find the sleeve very easily. It is available, but hard to find.
    Jan 2005
    levitown
    Quote Originally Posted by steve View Post
    maybe napa ?? is there a part number of any kind , where can i start to look for one ??????? my is okay but i like new especialy when it is a cheap part!!!!!!
    thanks for the history on the crank , i got this crank a year ago and its been on my mind .
    Feb 2005
    Cullman AL
    There is a crank shop in California...
    I do not know the name (but I can get it) that will add the material to the top bearing surface so you can use it without the shim.
    My understanding is the shim has always been a problem.
    Scott
    Gothenburg, Sweden
    Quote Originally Posted by gselite2000 View Post
    Probably Marine Crankshaft. There is a link on my links page (see below this post).
    Jan 2005
    levitown
    anyone out there know where i can get a new spacer???????????
    Folsom, Cal
    Quote Originally Posted by Markus View Post
    DITTO
    David at Marine Crankshafts in Santa Ana
    Dumb to use another spacer IMO
    David welded/machined mine up and now i dont have to worry about a shim comeing out now
    "Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
    2007 Sportsmen Driver of the Year
    I would NOT trust ANY crank that has been repaired ( built up via welding and turned down ) on any high performance application where the fix was applied above the upper middle main bearing ! ( #1,#2, rod journal or flywheel and seal area ) I have had ZERO luck with repairs living in those areas in the past.. AND David used to warn of the fixes in those spots on the V-6 mercury cranks and HIGH failure rates..
    I have written response posts about a successful way for me and my customers and you can use those cranks with no heat applied at all . It intails machining down the bearing OD area on the crank, pressing on a thicker "Press able" 4130 sleeve with an interfearance fit (the stock shim is tissue paper thin and sometimes impossible to now press on the scared up OD on the crank without wadding up ) then turning the OD of the new sleeve down to the correct standard size ID of the SKF 5208 W CI bearing to be pressed with an interfearance fit. I have several of these cranks running in ultra high RPMed drag motors for years...
    my .02
    Jay
    Jay @ JSRE
    Jan 2005
    levitown
    Quote Originally Posted by stoker2001 View Post
    DITTO
    i contacted marine crankshaft and they want to weld it , my crank is not damaged but the spacer is a little loose and it would be cheaper to just get another spacer i thinkl
    Nov 2004
    LEBANON OREGON
    id follow jay smiths reccomendation...
    Jan 2005
    levitown
    Quote Originally Posted by Jay Smith View Post
    my .02
    Jay
    this sounds like what i want to do , the one good thing is my crank top journal isnt damaged the spacer is just a little loose and i dont like it !! and would like to get a new spacer maybe a few this way when i tear down the motor every few years i can just change out if it is a little loose .
    the problem is just dont know the part number or who has them????????!!!!!
  12. #12
    Mercury at one time had them BUT you had to "know" somebody to get one
    ( sleeve ) ... They would much rather sell you a new crank than sell you a $10.00 sleeve to put on a mis sized POS crank they palmed off on some of their customers...
    my .02
    Jay
    Jay @ JSRE
  13. #13
    Jan 2005
    levitown
    my .02
    Jay
    so i cant get them
    does anyone out there have them?????????????????????????????
    somebody must have a whole bunch sitting in a 5 gal bucket
    give me a call
    either this or i can use the older style top cap , i havent had the topcap area bored out yet
  14. #14
    AHHH I wish ya luck finding one...
    Jay
    Jay @ JSRE
  15. #15
    Jan 2005
    levitown
    Jay
    what about the other size you were talking about
