Results 1 to 5 of 5
    Jan 2008
    Pittsburgh, Pa
    overheating at 3000 rpms
    I have a 33' avanti center console with twin 250 yamaha two strokes. The port motor loses water pressure at 3000 rpms. Yamaha replaced the entire head and put a new water pump in. Still loses water pressure at 3000. Yamaha switched the motors and the problem followed the side of the boat and not the motor. I had the hull surveyed and nothing is wrong. The only suggestion I have had is to check the exhaust housing adapter plate. I can't find it on the schemetic in the manual, and I need suggestions. I have owned the boat for twenty years and never had a problem. Will low water pickups help?
    Melbourne , Australia.
    when they swapped em over , did they swap just the powerheads or complete engines.?
    THERES A FINE LINE BETWEEN A GOOD WHEELMAN & A COMPLETE NUTCASE
    Ft. Lauderdale, Fl
    Have you added anything to that side of the boat like a transducer or water pickup?
    Jan 2008
    Pittsburgh, Pa
    Both engines, and then swaped the lower units. Actually tried it both ways.
    Jan 2008
    Pittsburgh, Pa
    I have not added anything to that side of the boat. The only thing I had done was to have the bottom painted. I can't imagine that could have anything to do with this problem.
