Results 1 to 14 of 14
Thread: Best epoxy resin?
11-29-2007, 05:11 PM #1
Best epoxy resin?
I am currently restoring my 16ft GW Invader. New transom, stringers, core, floor. I was wondering what is the best epoxy resin to use? I have used west system before but it is kind of expensive. Is there any others out there that compare to the quality and performance of the west system epoxies without the hefty price tag?
1970 16ft G.W. Invader~1969 1250 Merc
1971 15ft G.W. INVADER~1974 1500 J Block
11' glen-l TNT
16' Invader under restoration: http://forums.screamandfly.com/forum...hreadid=144970
"Where ever I'm going, heaven or hell I do hope they have an engineering department." ~ Elmer Carl Kiekhafer
11-29-2007, 06:55 PM #2
Try www.fgci.com they have a few different types
I pay $30.00 some ? a gal.We have invented the world; WE see
12-04-2007, 07:34 AM #35000 RPM
- Feb 2005
- North Shores of Boston
- 515
Many Quality Epoxy
There are many good epoxies on the market MAS has an easy fast or medium or slow catylyst which it convienent and The MAS stays clearer than most.
Remember don't smell it don't touch it and don't breath the dust if you keep that rule in mind -epoxy is safe to work with gloves and proper ventalation also epoxy fumes sink they don't rise, wash epoxy off your body with soap and water
I don't mean to be an alarmist - just be smart
James
86vintage
12-04-2007, 07:39 AM #4
Try John Greer.
Ló fasz racing
Joe Horvath
12-04-2007, 11:52 AM #57000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
the biggest difference is the specific weight of the resin. some lower the cost by adding toulene to the mix thus lowering the cost. but there not much difference in the actual material.
12-04-2007, 01:38 PM #66000 RPM
- Sep 2003
- Monmouth Beach, NJ
- 1,457
I've used a lot of epoxy over the past 2 years and can't say I had a whole lot of safety in mind when I did it. So I googled 'epoxy resin dangers' and came across this link. Its disturbing so unless you have a strong stomach don't click it. I highly recommend NO ONE try this with Epoxy or any other material for that matter. All I can say is "WTF was he thinking?" http://www.springerlink.com/content/y441825m5135088x/
12-04-2007, 02:19 PM #7
We have done lots of testing with the carbon FSAE race car and this stuff seems to be the best for weight to strength.
It does cost a bit though
http://www.westsystem.com/
There is also a proset that they make which is even better.
http://www.prosetepoxy.com/
They use to make a epoxy head that was the low end but i do not see it on there site anymore.
I really think that epoxy is something you get what you pay for.Last edited by JrCRXHF; 12-04-2007 at 02:26 PM. Reason: spelling
12-04-2007, 02:38 PM #8I really think that epoxy is something you get what you pay for.
Ló fasz racing
Joe Horvath
12-04-2007, 02:46 PM #9
From the testing we did resin cost of around 70-80 dollars a gallon where all pretty close
Resin less then 40 dollars a gallon was not even close in bond strength we did test a few different brands at the time. (3 years ago)
So all i can tell you is that the pro-set and west system both had good value.
And product support.
12-04-2007, 06:49 PM #10
Another thread mentioned Skater using epoxy. Anyone know the brand and type?
12-04-2007, 08:49 PM #11
12-05-2007, 08:48 AM #12Scream And Fly VIP
- Jan 2007
- Amityville/Lindenhurst
- 3,012
- 46
- 18
- 204
12-30-2007, 09:28 PM #13
Looks like a cool project gw. Why are you using epoxy? Is it an epoxy boat? Interesting link Mr Velocity!
12-31-2007, 06:51 PM #14
Always, always,always wear gloves
I wear two to three layers, your going to get holes and when one set get messed up you just remove one layer and keep going.
If you get sensitized , you may get some VERY nasty reactionsWe have invented the world; WE see
