View Poll Results: What Outboard Oil do you use?
Voters
18. You may not vote on this poll
  • Mercury oil
    3 16.67%
  • Alysin oil
    5 27.78%
  • Amsoil
    2 11.11%
  • Penzoil
    6 33.33%
  • Other
    2 11.11%
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 59 of 59
  1. #46
    Prince George B.C. Canada
    Good thread to bring back before everyone stocks up for the summer. Ive switched back to Merc Pluss only because I dont know were to get the alysin anymore for my 225 steel bore? Anyone in Canada distribute the right stuff for my steel bore motor and best gear lube?
  2. #47
    Have been using AmsOil for years without complaint, I find it makes more power than the others I have tried plus the clean burn at the dock. Had a talk with the Royal Purple guys and they claim thay the Purple HP 2C will out power the AmsOil 1-4% with far better flash and viscosity numbers and film strenght. As well as the special additive they put in, that make it outperform. I have used the 70-90W gear lube for years in the L.U. and the syn. 10w30 in the cars as well and have had very good results. The HP 2C is made to a higher level than TCW3, so they say. Has anyone used it?
  3. #48
    FMP I have not used the Purple but I have to say that Klotz has very similar claims and I have had great luck with their products. I have been using synthetics (Mobil 1) in my all my 4-strokes for yrs. Gary
    "77" Hydrostream Viper "87" 140 Rude heavy modded w/15" mid, Bobs nose and lwp (in progress)
  4. #49
    Klotz , I will check it out thank you Gary.
    Any other product sheets to compare to these Purple numbers?
  5. #50
    The Alisyn sheet, and I can say by talking with them that this is no snake oil. I was told since they do not use any solvents, this put the flash point at 500-600*F. I will check on this temperature .
    Attached Thumbnails Attached Thumbnails COMPARISON OF ALISYN PROPOWER 2 WITH PROPOWER 21.pdf
  6. #51
    Call them directly, they will send it to you.
  7. #52
    Cross threading with the latest what oil to use thread. Data sheets for Alisyn and Royal Purple
  8. #53
    Used the RP this season, good product.
  9. #54
    attleboro mass
    penzoil but gonna try amsoil
    1980 Hydrostream Vector w/ 1980 Merc 2.4 225
  10. #55
    Aug 2015
    Silver Spring, MD
    Jay Smith recommended Pennzoil from WalMart when I talked to him. He also said he wouldn't run Amsoil in his weed eater.
    1996 Four Winns Unlimited U-19 351 I/O Deep V
    1977 HydroStream Viper Merc 1500 XS
    1981 Baja 17 Bow Rider Merc 1500
    2 Pool Rafts
  11. Likes Capt.Insane-o liked this post
  12. #56
    Dec 2011
    Ludington michigan,on the shore
    Well I have decided to be the guinea pig.Ill be switching over to a complete load of BND automotive products this spring.Will be aces fuel treatment with pump gas,Quantum blue oil,and a Quantum blue lower unit lube mix for our colder water.This will be working its way through a 30 hour 280,that will get a head and rear cover pulled, for a look before spring.IF! its still running in the fall,Ill take another look and report!! Good or bad---BTW the breakin on the 280 was on Penz dino oil then about 25 hrs on Alisin, No problems of any kind
  13. #57
    At what compression and spark advance?
  14. #58
    Cabellas signiture semi syn @ 10 bucks a gallon.
  15. #59
    Dec 2011
    Quote Originally Posted by Mark75H View Post
    Brian recommended 2oz per six gal of 93 ethanol @ 175 psi @23btdc may try 50% 100LL
Spinelli Props
