Page 11 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 151 to 165 of 177
  1. #151
    Quote Originally Posted by shadowcat View Post
    - incredible picture of the moli's- where did they all go??? (and I think I know) -got any others to post here??? SHADOWCAT
    Where did they all go is a reoccurring question about old race boats ... when they are newly obsolete ... they just sit in some otherwise unused space, generally outside in the weather. Secondly, raceboat construction is light and never intended for long term ... it would be a conflict to build a raceboat intended to last 10 years, much less 20 or 30. This made the very susceptible to falling apart very quickly ... long before anyone would have interest in restoring one as an antique or nostalgia piece.
  2. #152
    gibsons, bc
    #32 Jim Hauenstein #37 Ron Traen #54 Gene Hudgens #157 Dick Sharp #1022 Jim Thompson
    Quote Originally Posted by htower View Post
    I took a better shot of the photo. Sam maybe you could blow this up for everyone. thanksAttachment 223412
  3. #153
    Feb 2012
    Plumas lake ca
    WOW thanks for posting the pic. #37 was my grandpa Ron Traen he passed many years ago now. It was great to see thank you so much.
  4. #154
    Mar 2007
    Glastron Molinari Restoration Update
    It has been far too quiet on our restoration program for my own satisfaction...but sometimes business has to be put before fun.
    At any rate, we are getting back to the restoration of Dick Sharp's Glastron-Molinari 18-footer.
    Running her at Clayton this August is the goal.
    The new transom is in and we are getting ready to install new strongbacks to give the hull/transom joint more strength.
    Jeff Ettinger is starting on the Evinrude KC13R and most of the old hardware has been found and cleaned up. (Throttle pedal, steering components, Keller speedo, OMC tach).
    We do need some info on is the fuel tank...which isn't to be found.
    What did they most likely run in the boat when set up for Marathons? Any photos out there?
    Any input would be appreciated.
    Thanks ...
    Joe Schulte
  5. #155
    Apr 2006
    Spring City, TN
    Hey Joe,
    Sure hope to see you at Clayton. Looks like we might have a good group of OPC size outboards there this year. I know that Ted Boyd has his wing ready and that John Tiger should have his Seebold /OMC V4 done by then. Have heard that Jack Beatley is considering bringing the #250 Molinari/T2x. I certainly plan on being there with my O'Berry Marine Molinari / Johnson RS. Too soon to say whether some of the others will show: Brian Pitt - Molinari / Merc V6, Scott Rotharmel - Molinari / CCC, Rich Luhrs - Switzer Wing / S3000's, Ken Fornwalt - Allison / Merc, Steve Larkin - Velden / OMC V4, Bud Clarke - Molinari / I-6 and Arnie Rubinstein - Switzer / I-6.
    >>>>>>>> Now that would be a heat of OUTBOARDS!!!!! <<<<<<<< We'll just pray for calmer waters.
    Quote Originally Posted by opie see View Post
    Thanks ...
    Joe Schulte
  6. #156
    Mar 2007
    Roger...
    One way or another I'll be there.
    Hopefully with the Galstron-Molinari and the DU that Allen Blide is putting the finishing touches on.
    I know the DU will be done....the Molinari has just taken way too long...and I have nobody to blame but myself.
    Hope to see you in August, if not before.
    Joe Schulte
  7. #157
    Jul 2004
    ontario- Canada
    Joe & Roger...I hope to be bringing 2 boats - the wing and the glastron molinari should be done (may not be running though) -joe -check your pm's for one from me
    Ted
  8. #158
    May 2002
    Granite Quarry, NC
    Thanks ...
    Joe Schulte
    The most common tank was a 40 to 60 gallon round aluminum tank as sold to big semi truck manufacturers. these had big fuel fills and adequate baffling. They were either strapped into a cradle or foamed and strapped into a box.
    20 Foot Switzer Wing 2 X S3000 (Dust'n the Wind II)
    !6 foot Wood Eltro Vee (2X Merc 1500's) (Dust'n the Wind IV)
    15 foot Powercat 15C (2 X Merc 1500) (Dust'n the Wind III)
    (Single engine boats are lacking something)
    15’ Wooden Switzer Shooting Star...
    16 foot Lee Craft Merc S 3000-(Gold Dust II)
    (The exception proves the rule)
    Obsolete and Proud of it
  9. #159
    gibsons, bc
    Up here in the Pacific Northwest, in the late '60's & early '70's, for a fuel tank, we were using used aluminum "beer kegs!" We simply cut a hole in the top (when lying on its side) for filler cap & rigged a fuel line (with shut off) out of the back bottom! We then built a custom glass/wood cradle & used numerous strong straps, to secure! Looked cool, worked good! But, first we had to drink all the beer, in the keg! LOL
    Quote Originally Posted by T2x View Post
  10. #160
    Mar 2007
    Mark:
    So far, I like your suggestion best.
    I presume I should use a 'Lite' beer keg to keep the wieght down....both the driver's and boat's.
    Apr 2006
    Spring City, TN
    Joe, The tank I put in my Molinari is huge...definitely a marathon tank. Funny, but I don't have a good picture of the tank in the boat. Here's one with it beside the boat as I was restoring it.
  12. #162
    Oct 2007
    Finger lakes upstate New York
    Gentlemen,
    I have one of the old Glastron Molinari tunnel hulls. I purchased it a long time ago, best guess 1982 or '83. It was stored indoors for 25+ years. The storage building was torn down and the boat has been sitting outside for the past 3 or 4 years. It has a plywood transom and balsa core for the hull. Click image for larger version.
Name:	tunnel hull, 9-19-09 042.jpg
ID:	316111Click image for larger version.
Name:	tunnel hull, 9-19-09 037.jpg
ID:	316112Click image for larger version.
Name:	tunnel hull, 9-19-09 048.jpg
ID:	316113 I always planned on restoring it. I Registered it as home made as there was no identification tag, or other identification on it. If anyone is interesterd in the boat let me know.
  13. #163
    Feb 2003
    East Galesburg, IL
    If you look in the middle of the picture, awaiting the start of the 1972 Havasu race, boat #44 is me with a Sid-Son tunnel from a lofted Molinari provided by Jack Leek.
  14. #164
    Jun 2014
    Goldsboro, NC
    I have read this thread with interest (and a few flashbacks). Somewhere in the back of one of my closets is a yellow with black stripes Glastron/Molinari racing jumpsuit. I should go find it and send it to you guys...
  15. #165
    Jul 2004
    ontario- Canada
    does it look like this
    Quote Originally Posted by Barracudamooda View Post
